I have 2 Boss Therm BZV22 valves. The one for the central heating has started to buzz but seems to work OK. What is the problem and what do I need to do to fix it. If the answer is get a new one is it OK to use it until I get the new one
3 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: stanley twin burner cooker.The cooker
Sorry, wrong part of the country. Were from OK. and we don't that type of systems>
Posted on Aug 26, 2008
friarturk
The switch (between both thermostat dials) only switches the central heating on when it's in the down position. When the switch is up the CH is switched off. Water is heated in both positions.
I use the switch as a CH on/off switch.
LOL just noticed the date it was posted...sigh..
Posted on Oct 28, 2016
Any ideas where to buy a Boss Therm BZV22 or the equivalent Siemens RMH? Many thanks
This is a two port zone valve used in plumbing. Why is it posted in Cars and Trucks? I did find it available online at Havelock Controls.
Nov 24, 2014 | Cars & Trucks
No heat
sound like radiator clogged.have coolant system flushed
Dec 31, 2012 | 1990 Geo Prizm
RADIATOR IS NOT WORKING
If you Bled air out, were you able to hear the water take its place? If not and you have a zone valve installed, see if you can manually override the valve to get water flowing again
Jan 01, 2010 | Desa International CBN30T Central Heating...
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
1992 cabriolet will not idle
The ISV (Idle Stablizer Valve) could be clogged or just not working. It's a cylinder with 2 vacuum lines and electrical connector going to it. Just above the valve cover and below the intake manifold. Best check for that is turn the key on engine off and the ISV should buzz. If it is buzzing remove it and clean it with some throttle body cleaner or brake clean. Reinstall and check for idle concerns. Have to be quick to see if it buzzes though. Better to have someone turn the key for ya while you check the valve. If it doesnt buzz replace it. Also check the switched on the throttle body. See if any of the wires are broken.
May 27, 2009 | 1992 Volkswagen Cabriolet
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Heating & Cooling Logo
169 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
