Heres a unfreeze help just click on the link just go little bit down and you have to follow the steps to unfreeze your phone http://www.unlockallcellular.com/samsung-s5620-monte-unfreeze-code-p-54599.html
SOURCE: dcan anybody please tell how
Hi, problems with mms message, mms settings are usually from your network provider
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
If you can't receive or send mms messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use)or you can confirm by contacting your service provider service and they will assist you by sending you the settings for you mms message
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
SOURCE: i want samsung gt s
You doesn't need any special software.This feature is already given in your phone . just call any no. and unlock the screen tap on "more" option and and select the record call option. your call will be recorded. go do it.
SOURCE: how to download and instal
Yo! I will have to direct you to a website where you can download anything for your phone. please follow the links below.
www.download.com
getjar.com
waptrick.com
4shared.com
http://www.filehippo.com/
