Question about Interface 2008/2009/2010 Saturn Vue Ipod/iphone Adapter Interface
When I plug in aux cable to aux port to play ipod in 2008 Saturn Vue, sound is only coming out of passenger side speakers. This just started happening. All speakers have sound with normal/satellite radio. Problem only occurs when using the Aux port.
Dang this is my problem too. have you figured anything out?
Posted on May 21, 2011
Where is the location of low side AC port
Search "low side ac port Saturn vue hybrid". I got a good few hits suggest you do the same. I don't know enough to help you further.
Jun 16, 2015 | 2008 Saturn Vue Hybrid
Plays well for a few minutes than screeches, unplug the ipod and then plug ion again and same thing happens again. Any help for this?
Try spraying the iPod port and cable end with compressed air, or blowing on it with a dry mouth. Sometimes dust ends up messing with the electronic connection between the metal pins.
I would try a few different speakers such as an AUX port in a car, headphones, or a stereo system to eliminate the possibility of the problem being with the iPod itself. Consider replacing the speaker if it's still under warranty - it may be faulty.
Sep 30, 2013 | Altec Lansing Im-237 Orbit Ultraportable...
Can i connect ipod to technics hifi?
yes you need to buy an ipod coonector that has the rca plugs at the other end - plug the cable end into the auxiliary ports on the rear of the amp processor unit, then connect the ipod as normal but switch the out put selector to aux and you clan play your ipod through the speakers. one thing this wont charge the ipod while playing
May 07, 2012 | Technics SC-DV290 System
No sound from the pipe unless I plug my phone into the aux...then it only comes on the right side.
I made the same mistake and had the same issue. You cannot use the line in Aux plug at the same time as the iPod. Unplug the line in aux cable from the pipe and the iPod will play beautifully in the pipe without it.
Dec 25, 2009 | Skull Candy Pipe Speaker Dock for iPod and...
I dropped my On Stage micro and now when my iPod is docked and the on stage is powered on their is a LOUD buzzing sound from the speakers. The auz-in mini plug still transmits sound and music fine, only...
I have had then same exact problem, except I had an ihome. I've done research on it for a way to fix it. basically what I have come to find is that the plug for the ipod is just cheaply made, and that there is basically no easy and cheap fix for it. However as long as you have an aux-in you can just simply avoid the problem by buying an eighth inch to eighth inch cord so that you can just simply plug you ipod into the aux-in. As long as you have the ipod plugged into the the aux-in, and aux mode is selected, it should play your music while charging.
Sep 21, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
Harley Radio aux port not working?
The problem is you have a bad aux plug for repair info you can email HRmotors@aol.com- Thanks
They usualy ware after time and start making bad connections
Jun 26, 2009 | Harley Davidson 426290 AM/FM Radio
Hi I have a Altec Lansing InMotion iM9 Stereo for my ipod and it comes with a port for an ipod in the back, i assumed that it would play my computer audio threw it but does nothing. What should i do?
This may be obvious, but have you plugged your computer audio output into another speaker to make sure it works? You have to make sure you turn the iM9 volume up as well as the volume on your PC audio. The AUX input "mixes" with iPod audio, so you can leave the iPod in the dock, however, you should turn it off when playing music through the AUX port.
Feb 28, 2008 | Computers & Internet
Interface 2008/2009/2010 Saturn Vue Ipod/iphone Adapter Interface Logo
234 people viewed this question
Top Interface Car Audio & Video Experts
xxxxxx xxx
Ted Maxwell
Are you an Interface Car Audio and Video Expert? Answer questions, earn points and help others
