Hello - I have a Kenmore Laundry Center model 417.94862302. Now and then the washer makes a high pitched screeching sound that turns into the sound of a whistle during the final spin. I figured the loads are too heavy but that doesn't always seem to be the case. What is wrong? If it needs to be repaired, how much should it cost? Thanks for your help! This is a great forum. Jana
dididsaythat
  • 291 Answers
SOURCE: kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Posted on Sep 07, 2007
  • 6 Answers
SOURCE: series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Posted on Jan 14, 2008
  • 223 Answers
SOURCE: kenmore front load washer 417-44082400
I think the problem points to worn brushes on the motor. If you are able to replace them yourself if not seek out a qualified technician. Hope this helps.
Posted on Jan 18, 2009
SOURCE: Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
Posted on May 21, 2009
  • 274 Answers
SOURCE: Maytag washer (model PAVT244AWW). Won't spin.
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Posted on Jul 05, 2010
Testimonial: "Response was helpful to figure out our options!"
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
2006 Chrysler sebring High Pitch Noise Screeching Sound
The belt is slipping or the compressor and/or clutch is bad.
If the compressor won't turn freely with the engine off, it may be locked up which will make the belt screech.
Jun 27, 2012 | 2006 Chrysler Sebring 2.7
What could be causing a high pitched screeching sound when I turn on my single handle shower?
If you haven't turned the main back on, this could cause the sound.
Re supply the water to the lines.
May 10, 2010 | Moen 3175 Legend One Handle Shower Faucet...
My dryer makes this high pitch screaming noise...what's going on?
In the cradle where the center drum bearing fits is a plastic bearing mounted on a metal bracket. When that plastic bearing wears down the ball begins to contact the metal bracket. Bad things are ahead also. Because now as the drum turn the bracket is cutting into the ball.c44ef56.jpg
A typical Laundry center repair manual
Mar 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
My range is making a siren (high pitched) sound. The control panel is not lit, but I can get heat on the burners. Kenmore Range Model 911.6408810. Unfortunately I can't put my hands on the owner's manual...
Hello- Gas valves sometimes find a flow rate or valve position that can cause noises from hums to screeches. However- if control is out, gas valve won't function normally anyway. Had trouble with mod # provided above to check on parts but control if still available runs around 250$ Gas regulator around 100$. Hope this helps. Thanks- ED
Feb 28, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Portable Washer will not agititate
MOST KENMORE WASHERS HAVE A COUPLER BEWEEN THE MOTOR AND THE TRANSMISSION AND THEY BREAK ALOT,YOU CAN TIP IT OVER OR REMOVE THE FRONT PANEL AND SEE IF IT HAS BROKEN,LET ME KNOW WHAT YOU FIND-MIKE
Nov 01, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
