Question about Refrigerators
Our Kenmore Side by Side refrigerator ice maker is not working- I'm not sure I found the correct tag inside the refrigerator side of my side by side that said: model #596-526-79202 ... Serial# 11360692CX ... The problem I am having, is that when I entered the above model and serial #'s into my computers for the search, I am unable to find the refrigerator ; the ice makers trouble shooting manual... how to tighten door handles ... servicing schedule. Where should I be looking for the correct Model # and how do I get the trouble shooting manual on line, I will also- need to know, How to tighten the door handles on the same refrigerator . Thank you, Bob my email address is : rsitch1@gmail.com
  • Refrigerators Master
  • 4,654 Answers
Well that is better model numbers than most people give! The first three numbers say the refrigerator is an Amana. Sometimes the Kenmore and the OEM number gets lost in the translation and it makes it a little more difficult to pick the exact model number by Amana. Sears Parts Direct you will need to put the numbers together like this=> 596.52679202 Repair Clinic can also convert model number to parts here=> 596.52679202 You can also go to Amana and begin your search by features=> Our Kenmore Side by Side - sea_breeze_118.jpg Click Logo This is where Sears drops the ball and you will need to compare => side by side's French Door and then=> Literature again until you see your model number
Then=> Once you see your model click=> Literature
That breaks your model number into Use and Care (1616.87 KB), Warranty (126.21 KB), Dimension Guide (78.58 KB), Energy Guide (97.01 KB), Specifications Sheet (434.26 KB) Once you find the exact Amana Model Number I will pull the Service Manual up and need to contact you a different way because they will not let me post their Service Manuals here. Sea Breeze
I hope I have not confused you but that is the way you will need to get the answers once Sears changes the model number. Your model uses a=> 67003153 Ice Maker Assembly That ice maker is made up of components that sometimes fail. Here I leave you with a short tutorial. If you have further questions please contact me here or Fixya, Thanks, Sea Breeze
Posted on Mar 18, 2011
My kenmore side by side is not producing ice and there is a red light blinking inside the freezer sec
Can you locate your model number inside the fresh food section around door frame? I believe you have the ice maker with the electronic eye and sounds like you need to follow these instructions so the ice maker works again. If I am wrong then please correct me by posting your model number that should look like this example=> 321.234567 Click Here=> Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here if you need to ask questions, Sea Breeze
Nov 30, 2013 | Kenmore Side by Side Refrigerator
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker won't stop making ice
If your shutoff arm stays up, the switch inside is bad. Usually have to replace the entire icemaker. Send model # from tag on fridge for part lookup. hope this helps!
Jan 05, 2009 | Kenmore 55693 Side by Side Refrigerator
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
