Question about Pioneer GM-5300T Car Audio Amplifier
Are subfoofer ts-w308d2 and amplifier GM-5300T compatible with each other?
    Scholar:
  • 71 Answers
Yes. You will be able to run this setup with the sub bridged across both channels of the amp, which will give you more power (which the sub will be able to handle: 380 watts rms), or with the sub wired to a single channel, which will give you less power (125 watts rms). The sub can handle 400 watts rms.
Posted on Mar 20, 2011
Cuts off at loud volume
Acoustic cutout protection? Also protecting your hearing!
Jan 21, 2016 | Pioneer GM-5300T Car Audio Amplifier
Wiring
you have the remto wire hook up it blue from deck to amp?
Jul 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
The outputs on my Pioneer GM-5300T are intermittent and low
yes they are perfect whenever I turn up the bass it just trips on and off
Feb 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
My pioneer gm 5300t amp cuts off at loud volume and will not kick back on until it is turned down and cools off, what is wrong with it?
You are over heating it,You have your speakers wired up for a lower,(OHM) Rate then the amp can handle, That why it cut out when you have it turn up
Nov 10, 2012 | Pioneer GM-5300T Car Audio Amplifier
Hi, I installed my system myself and I'm having trouble with my Pioneer GM-5300t getting really hot. I'm trying to find out what might cause this. Could it be that I have a bad ground or I have the...
it could be the wires from ur sub to the outside box ,like on the inside of the speaker box ,power an ground should be the same but not always. if its new it sometimes mite have a smell .
Jun 03, 2011 | Pioneer GM-5300T Car Audio Amplifier
I parelled one 15" q power subwoofer to my brideged pioneer amp.The amp got really hot and blew a fuse.How should I wire my dvc subwoofer to the briged amp.
Hello sir, hi, YOU DON'T bridge no more speakers, this upsets the impedance load of the amp. to install another sub-woofer, get another amplifier. You may have damaged your power amplifier, If you experience repeated fuse blows, your power amplifier is now SHORTED. This needs IC amplifier replacement.
Aug 19, 2010 | Pioneer GM-5300T Car Audio Amplifier
I have the choice of hooking up my subs either at 2,4 or 8 ohm. How do I know which is the best?
Your subs are rated at ether 2,4,or 8 ohms it is usually printed on the back of the speakers
Feb 24, 2010 | Pioneer GM-5300T Car Audio Amplifier
I have a Pioneer GM-5300T amp wired to a 10 inch kicker sub. The music plays throughout the speakers of my car but the sub goes in and out. I noticed that the amp's power light dims when the sub goes in...
Hello pburgfootbal,
You do not specify which Kicker sub you have or how it is wired to the amp. The GM-5300T is only stable to 4ohms in bridged mode and if your sub is a 4ohm DVC with the coils in parallel, it presents a 2ohm load. If the sub is 2ohm DVC with the coils in parallel, the load is only 1ohm. Either configuration would be too low of an impedance for the amp in bridged mode. I'd check the sub specifications and make sure that the wiring configuration properly matches it to the amp.
Hope this helps.
Jul 31, 2009 | Pioneer GM-5300T Car Audio Amplifier
What does the system control wire get hooked up tooo??????
it's just a remote wire it goes from your amp to the car stereo. usually on the wire harness for your cd player the color is BLUE but it should be labeled.
Mar 10, 2009 | Pioneer GM-5300T Car Audio Amplifier
Pioneer GM-5300T Car Audio Amplifier Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
