Question about Magic Chef Washing Machines
Magic Chef washing machine does not drain. - Magic Chef Washing Machines
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
Testimonial: "I thought my washing machine was shot. But thanks to your advice, I took off the back plate and found a sock stuck in the drain pipe. Thank you!"
SOURCE: Washing Machine Won't Spin/Drain
Apparently, there is an issue with this model. Get it checked out. I did.
Posted on Oct 05, 2007
  • 5 Answers
SOURCE: MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Posted on Jul 19, 2009
  • 4088 Answers
SOURCE: my washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Posted on Aug 01, 2009
  • 129 Answers
SOURCE: MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Posted on Feb 02, 2010
Magic chef error E4
E4 indicates the washer failed to drain out after 4 minutes, after that time the code is set. Check and clean the drain filter first.
Jan 19, 2017 | Magic Chef Washing Machines
How do I open the top part of the washing machine?
Unplug the machine. If there is a fault with any aspect of your washing machine and you are going to get inside the machine, then there is no reason to risk the possibility of an electrical shock. The machine may have to be pulled away from the wall slightly to remove the wall plug. For More information please visit Clothes Washer Parts .
Oct 07, 2012 | Chef Cooking Magic Chef Washing Machine...
Margic Chef washing machine makes loud ginding noise when agitating and on the spinning cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Magic Chef CAV4000AWW Top Load Washer
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
My washing machine drains but does not spin
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Jul 31, 2007 | Magic Chef CAV2005A Top Load Washer
Washing Machines Logo
280 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
