Question about Refrigerators
I notice pools of water on the inside of my Whirlpool refrigerator on the left side. The freezer and refrigerator are set at the recommended settings. Is there a way to get to the drain hose to make sure it isn't clogged? Thank you in advence for your help. Stephanie
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Water is leaking out of inside bottom vent of freezer and pooling and freezing on bottom under pull-out container unit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water is dripping down the back of the refrigerator inside and pool in the bottom of the refrigerator. Whirlpool/ freezer on top ET-1CHMXKQ02. Freezer is still working and icemaker is still making ice.
Defrost drain tube is clogged. Have to clear this by removing back wall inside freezer and removing the ice build up inside the defrost tray and tube. Very very hot water and hairdryer will help with this process. hope this helps.
Jan 28, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator - condensation, ?clogged drain
The stopped up drain tube is inside the freezer probably behind the rear wall. There should be screws in it to remove it. Remove any ice at the bottome and you should be able to see it. I don't know about the wheel.
Aug 14, 2009 | Refrigerators
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water pools under the veggie crisper
yoor problem is with the drain, when your refrig goes into self defrost the water melted from the defrost needs some where to go. There is a drain for this purpose....it is normally a tube that leads from the rear of freezer to pan by compressor. when this gets blocked the water has nowhere to go except into the freezer vent and down the bottom of the refridge compartment. you will need to clear the blockage in the drain tube...if you are still haveing a problem i can tell you how.
Jun 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
