Question about Microwave Ovens
Microwave model MH1150XMS-0 I just bought a black handle for door. Cannot get outer door off to get to to screws to insatll handle
  • 1 more comment
  • Michael Brennan Mar 18, 2011
    Daniel I tried to do as the video demonstrated but could not get apart. Your video shows to
    what appears a shallow shell.. Mine is approx 3/4 in. I am afraid if i pry too hard I will
    break the plastic.
    I tried to do as the video shows but I could not get shell off. In video the shell apears to be very thin.
    Mine is approx 3/4" in after prying I am afraid I will break plastic
    Daniel I viewed the video and observed that the outer shell looked so easy and it looked like it was
    thin. Mine is approx 3/4"in and hard to pry off. afraid i might break the plastic.
  • 4,323 Answers
Hi
Please check this video for door handle replacement:
Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 18, 2011
  • Daniel Scott
    Daniel Scott Mar 18, 2011
    Thats how its done however you can also check this diagram
  • Daniel Scott
    That's the way it is done however,
    please read this "To replace the door handle you
    need to access the door handle screws. On MOST microwave ovens, you just have
    to remove the inner door panel that goes around the perimeter of the glass.
    This can be easily be accomplished by using a small screwdriver or putty knife
    and carefully insert along the seam of the inner panel and pry the plastic up.
    Work your way slowly around the perimeter of the glass to pop the panel loose.
    Use care not to pry against the glass" (courtesy jsrock FixYa expert).
    Hope
    Daniel
    That's the way it is done however, please read this "To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass" (courtesy jsrock FixYa expert). Hope this helps...please post back for further assistance.
    Daniel
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
Microwave door handle
Hi have a nie day!
You may use a electric drill and the a screw extractor so the handle be released.
Mar 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Broken handle on maytag stainless steel microwave. Do not wish to purchase complete door assy. Could possibly substitute a black handle. Model MMV5165BAS. Kindly advise
around the inner side of the door between the window and outer frame is a plastic shroud,by gentle prying it out using a flatblade screwdriver starting at the handle side working toward the hinge side it will pop off and the screws that hold the handle can be accessed and remove and replace the handle. to reinstall that shroud gentle push it in with your fingers
you can go to searspartsdirect and enter in your model number exactly as found in the mw cavity and order the part or perhaps look in your phone and find a appliance parts dist. in your area
Jul 19, 2011 | Microwave Ovens
GE Microwave model JVM1650CH01. Trying to replace door handle." I have removed panel on inside of door and removed 2 screws to handle. It appears that there are screws holding the outside cover of door...
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
May 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
I have a JVM 1650BB008 GE microwave oven. I am trying to replace the outer door frame and handle, which are broken. I have removed the door and have pried off the choke cover. Now I need to remove the old...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You have to remove the door handle screw(s) and the door handle, then look for subtle clips that may be holding the outer door screen in place.
Some models have two screws holding the door handle, but some have only one. In that case, remove the screw, then you either lift or rotate the handle to free it.
If you still need help, please write me at prototech@usa.net for the service manual link (no charge, no obligation).
Sep 27, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
My over the oven model 665.61629100 kenmore has cracked door
The outer door frame CAN be replaced if you like. You can view an exploded view diagram at searspartsdirect.com. Just type in your model number and locate item 10 under the "Door" parts listing. The part comes in various colors so make sure you select the correct one.
The door can be easily removed by opening it all the way and lifting straight up at the hinges. The door will come off the hinge pins and can be laid on a flat surface for easier access. Place a layer of towels under the door to prevent damage to the door.
You will need to remove the door handle to get the outer door frame off. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you may need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and and locate any screws that may be securing the outer door (front) frame in place. Once you install the new outer door frame, re-install the door handle and carefully re-insert the inner door panel. Gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
To answer your initial question, the microwave should continue to be safe to use as long as the inner door seal and door glass are intact. Make absolutely sure you reinstall the door components back together properly. Not doing so will render the oven unsafe to use. Refer to the web site I provided as a reference for how the door components go back together.
NOTE: This part is listed a bit cheaper at appliancepartspros.com. Use the part number from the first website I mentioned as your search criteria.
Jul 30, 2009 | Microwave Ovens
Whirlpool microwave model MH1150XMS-0 is not working
your door monitor switch has gone out. they are 3 switch that monitor the door. remove control panel. they are located behind frame where the door clips go into.
Jun 24, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Kithchenaid Microwave
You'll notice there are small clips holding the stainless outer door to the black metal inner door. Get a bunch of putty knives (butter knives work too) and work a knife into about every other clip. I did it on the bottom. Once you're sure all the bottom clips are free, and you've removed the three screws on the side of the door, you'll be able to gently pull the stainless outer door away from the black inner door and get to the handle screws.
I bent both doors in this process, and tore the black plastic liner into a few pieces while I was getting everything out, so I had to buy a new door ($200). Be careful.
Sep 09, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
106 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
