Question about Ibanez RGD Series - RGD321 Electric Guitar - Black Flat Finish - Free
Just bought the ibanez rgd 321 guitar.didnt come set up and fret buzz is overbearing the sound when played.can I adjust myself.if so,how.with the bridge saddles.dont want to raise action too much either.thank you very much.have a great day guys.
  • Ibanez Master
  • 5,603 Answers
View videos on "guitar setup" on YouTube. Quickest way to learn and also avoid mistakes on guitar setup !!!
Posted on Mar 18, 2011
  • spydrspy Apr 01, 2011
    More than likely you don't not have enough relief in the neck. Which requires a truss rod adjustment (slightly loosen).
EGS44BK4/4 MANUAL
I don't know what guitar this is because you need to be specific about make and model? but to set up your guitar the low E string #6 the height should be 6/64ths +/-a 64th and the high E string #1 should be 4/64ths +/- a 64th you must be careful because it's not just lowering the bridge saddles to do this the adjustment also has to do with the neck relief and the condition of the frets EX. if you have frets that are higher than others because you don't play there in that area the strings will buzz of the tops of those higher frets. you can try to do it and get your guitar more comfortable to play I don't know all the details here? how old, first, second owner makes a difference because of different playing habits of multiple people but if you do it and it works GREAT! but if you have the problems with buzzing and still not able to intonate the guitar it needs to be seen by a repairman for a (1)fret dressing=make all the frets the same height and reshaped (2)proper neck curvature adjustment =relief (3)intonation= putting the bridge saddle's in the proper place so the guitar is in tune with itself up and down the neck these things require a skilled repairman for the results you want and if you don't have the knowledge and training and tools to do these things you will only turn you guitar into a mess playing worse than ever and sounding terrible but don't misunderstand me here if your willing to learn how to do these things it will help you keep your guitar maintained and the cost of doing so down there are books you can buy showing you what you have to do to get your guitar straight and if yours is not an expensive model well then you can certainly try but if that's all you have to play I wouldn't! go buy some experimental cheap ones at a garage sale and learn on those you'll be glad in the end that I was the person who answered your question here before you started to embark on your quest for a smooth playing and sweet sounding instrument and only getting a nightmare in your hands with the roar of GODZILLA post back here for more info and help!
Aug 26, 2014 | Music
Jack female connector type
switchcraft
your standard 1/4 in mono female jack.
Mar 18, 2014 | Ibanez RGD Series - RGD321 Electric Guitar...
High action martin java mahogany 00x1
To lower the action on an acoustic guitar:
Usually just the saddle needs reducing.
1. Remove strings (or you may be able to just loosen them). Remove saddle, sand down the bottom a little at a time. Restring and check action.
The action can be set as low as poss without any fret buzzing or note choking on all strings and on all frets.
2. Repeat 1
If the action remains too high then there are other techniques.
Later ...
Jan 09, 2014 | Martin Guitars 00X1 Java Mahogany Guitar...
MY EPIPHONE ACOUSTIC BUZZES ON 11TH FRET AND SOUNDS SAME NOTE ON 12TH FRET
This means the 12th fret is a bit too high. If you are not familiar with adjusting frets take it to any local guitar shop for repair.
Nov 13, 2013 | Epiphone DR-100 Dreadnought Natural...
I am getting buzz, ******* noise with low Aon E string and open A, also the A on the 12th fret, its just below a, a flat is also causing a buzz, the micro tune is new, i had played with a friends over the...
This sounds like fret buzz caused by improper setup of the guitar. Likely the intonation needs to be set and the string height... possibly a truss rod setup as well. Take the guitar into a shop for setup unless you are adept at setting. There are a couple videos on guitar setup on YouTube, however do NOT try a truss rod adjustment yourself.
Jun 23, 2011 | Roland MICRO CUBE RX Compact Guitar...
Had my guitar PLEK'd because we found out the frets were defective from the company, this was supposed to fix the problem of high action, still cant get the action low without it buzzing
Take it in for setup. Likely the truss rod or the bridge is out of adjustment. Wrong strings can also cause the problem. There are YouTube videos on guitar setup... I would NOT attempt truss rod adjustment yourself.
May 18, 2011 | Ibanez S5470 Prestige Electric Guitar
My s5470 does not sustain well at all.also,the bridge pickup sounds ok but lacks ''attack'' in upper register.great guitar otherwise.i use a peavy 5150 60watt amp.
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks.
Apr 15, 2011 | Ibanez S5470 Prestige Electric Guitar
I bought a Hagstrom Ultra Swede which sounded very nice when I first bought it but after 3 months I seem to have alot of tuning problems with it. It has been intonated twice and a new set of heavier...
Considerations:
1. Intonation problems can be due to worn strings even if the guitar is set up properly. New Strings can fix this. This is the most common problem.
2. Also, changing string size may effect your set up too. Typically, new guitars come with lighter strings such as (9's) which the guitar is set up for. The positive is that 9's fret easily. The negative is that they bend too easily for some players who either slightly bend them when chording (accidentally), or press too hard on guitars with jumbo sized frets, which in turn bends the string toward the fret board causing detuning. To fix these items folks may suggest you get a heavier string like a (10), but the problem can often be solved by playing with a lighter hand, pressing only enough to make contact with the fret and not pressing the string all the way to the fretboard. Check your intonation using this light touch method and see if it's okay verses pressing the string all the way to the fretboard. If the intonation is okay with the light touch, the guitar intonation is set up properly. You may want to consider playing with a lighter hand or getting a guitar without jumbo frets such as Fender strats etc...
Putting a heavier string on a guitar set up for (9's) would likely cause the buzzing that wasn't there before. In this case you'd need the guitar and neck set up again to accomodate the 10's. So decide what size string you want and set the guitar up for that size.
These considerations are true for any electric guitars.
After consideration of all of the above, you still feel it's the guitar, I suggest you push for a replacement or perhaps credit toward another guitar.
Oct 18, 2010 | Hagstrom Swede Electric Guitar Natural...
Ibanez intonation problem
Hi there. Use guitar tuner. Pluck string in open position. Tune. Now pluck same string at 12th fret. If tuner says flat, adjust bridge for that string towards neck. Towards bridge if sharp. Repeat procedure until in tune at open and 12th fret. Go to next string and repeat procedure.
Thanks
Paul
May 11, 2009 | Music
When I lower the bridge of my ibanez grg170dxbkn to the required action of the strings(2mm bass)(1.5mm treble) my strings on the treble side produce a buzzing sound mostly on the 12 fret...do i need to...
I can understand it a bit of a daunting task setting up these guitars (I have bought at least 5 like this) But yes it might be the truss rod ... Without looking at the guitar myself its hard to say ... If you tighten the truss rod remember how much you turned the allen wrench because if it doesnt work your going to need to reset it and start again ... Remember to turn it the right way! and if all else fails ... If your near me (Bournemouth, South of the UK) then you can always pop on over to mine and I can take a look at it.
Failing that just take it to your nearest guitar repair shop and a setup should cost you about £30 if your in the UK.
Apr 07, 2009 | Ibanez Grg170dxbkn Electric Guitar Hsh...
Ibanez RGD Series - RGD321 Electric Guitar - Black Flat Finish - Free Logo
358 people viewed this question
Top Ibanez Music Experts
Michial Gueffroy
Wayne Tolonen
Are you an Ibanez Music Expert? Answer questions, earn points and help others
