Question about Ricoh Office Equipment & Supplies
Master roll keeps breaking and jaming - Ricoh Office Equipment & Supplies
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
I 'm sorry i don't under stand yo
Posted on Mar 19, 2011
Error A-01-211. Master roll not feeding properly.
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
OR replace it
Feb 22, 2013 | Riso RZ220 Duplicator
2000 ford explorer master switch problem
Check for broken wires inside the rubber boot from the body to the driver door . Happens all; the time ,wires breaking . Also you should have check for B+ voltage at the master switch before replacing .
How To Diagnose your Power Window Problem Is the Switch or motor bad BUY...
The Trainer 24 Power Window Troubleshooting
Apr 29, 2017 | 2000 Ford Explorer
Brakes have fialed twice at very low speep basically just rolling to a stop. pedal pulses and goes to floor before locking
You could need a new master cylinder.it sounds like air is getting in your break lines which as you know could be very dangerous.have checked your break fluid?
Jul 27, 2011 | Jeep Grand Cherokee Cars & Trucks
Left side window rolled down fine,went to roll up it went on an angel.
plastic attachments bonded to the sides of this glass (they keep the glass moving up and down straight) are bad about breaking when undue pressure is applied. You will probably need a new or salvage glass to correct this. lube the moving parts of the doorglass lift mechanism and silicone spray on the felt glass runs. something caused this to break and usually keeping the parts slick will help.
Sep 14, 2009 | 1994 Pontiac Grand Prix
Windows will not roll down after I have repaired the wire that goes from the master switch to the relay. I also have replaced the Master switch and I windows still will not work.
Check for power and ground at the motor (with switch up and down, powers and ground will reverse). If you have power and ground, at the motor, you probably have a faulty motor. If you don't, then there is probably a break in a wire, usually where the harness passes through in the door jamb. Actually first after removing the interior door trim, try to roll down the window while tapping on the motor with a small hammer. If it works, replace the motor.
Aug 02, 2009 | 2000 Jeep Grand Cherokee
1994 jeep grand cherokee power window problem
most of the time it is wires in the drivers door that break in the loom
Feb 20, 2009 | 1994 Jeep Cherokee
My poulan snow blower keeps breaking sheer pins in the wheels,
1)try replacing them with a heavy duty "roll-pin"
these are available from auto parts stores.
two types are available.
first is the "single-roll",second is the"multi-rolled"with many layers to it.
try both they're cheap.
2)try not hitting things with the blades
3)dont force the machine in heavy wet ,or frozen icy packed snow.
Dec 23, 2008 | Sport & Outdoor - Others
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
