Question about KitchenAid Dryers
Kitchen Aid Superba Model KEYS777EQD. Dryer was making a screeching/squealing noise when started but would go away. Then it would run for so long and then shutoff, had to let it cool and could run it again for awhile. Now it has stopped working altogether, was told that the motor and blower needed to be replaced. Does this sound like the problem, and if so is the dryer worth the cost to replace these parts?
SOURCE: The drier has no heat.
I have a repairman scheduled for tomorrow.
Thank you for the followup.
Posted on May 28, 2009
  • 1891 Answers
SOURCE: I have a kitchen aid superbra electric double
replace the left & right hinges ( if stainless door they have stronger hinges for this.. this is a very comm problem .. in some model you can use shim kit for this problem but replacing hinges is best avenue . mm
Posted on Dec 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer makes a loud squealing when first started
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 05, 2009
Testimonial: "Removed the drum and oiled the various rollers Quieted the noise. Sounds like a new one again. Thanks "
hunter19_46m
  • 7482 Answers
SOURCE: my amana dryer model is making screeching sound
Hi Peggy...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. BE REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 30, 2009
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
I have a 95 Buick Regal.It makes a noise when running ,but if take the belt off it stops.
it depends what kind of noise, if its a licking noise the pulleys that the belt is being turned by could be bad (belt tensioner pulley ,Idler pulley etc.) if its a squealing sound like a high pitched whistle or like a rubber heal screeching on a tile floor constantly the belt is no good there is fabric on the inside of the belt and when it wears away you will get the chirp or squealing /screeching sound from this. inspection of that belt will tell you look at the grooves if looks like shiny rubber you found it if it doesn't and the fabric is there then a pulley is the problem bad bearing can make the belt slip resulting in the squealing good luck LATER MAN!
Aug 24, 2014 | 1995 Buick Regal
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Squealing/Screeching Noises
well hi,i think it sounds like the belt,it will do it when clothes are wet,but as they dry it don,t do as bad. or dose it get worse when it runs for a while. either way it sounds like the belt.
May 30, 2009 | Dryers
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Dryers Logo
37 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
