Question about Sport & Outdoor - Others
I have a riding lawn mowers using model number 284707 briggs and stratton, I need a wiring diagram for the mower.
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
  • 152 Answers
SOURCE: oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
Posted on May 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: wiring for Briggs & stratton
Check out this Briggs and Stratton manual and see if it helps you sort things out:
http://www.mymowerparts.com/pdf/Briggs%20&%20Stratton%20Service%20and%20Repair%20Manuals%20Spec%20Charts/alternator_replacement%20with%20wiring%20diagrhams.pdf
Usually alternator wires are red and black. They also have an AC output that goes to a rectifier to make DC.
This is the standard B&S ignition:
http://www.mymowerparts.com/pdf/Briggs%20&%20Stratton%20Service%20and%20Repair%20Manuals%20Spec%20Charts/ignition_wiring%20basic%20wiring%20diagram%20BRIGGS%20&%20STRATTON.pdf
White wires can be for headlights or ignition kill. WHITE / Light wires usually come from the battery positive post.
Thanks for Choosing FixYa,
Kelly
Posted on Oct 09, 2010
Free belt diagrams
There is no way to get the diagram without knowing the model number. The model number will be under the seat most likely.
Jul 17, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Cant find a wiring diagram for my 17hp briggs and stratton 42inch cut yard machine lawn tractor it will not turn over with key i just got it cheap but have noticed three wires that are cut but dont seam to...
Try going to: http://www.manualsonline.com/
This download is free.
Most owners manuals have a wiring schematic diagram page in them. You will need the model # on this site to check for an online operators/users manual. Most REPAIR manuals on the net are either book or CD and are not free.
Aug 29, 2010 | Yard Machines 155 Torque Briggs Stratton...
Need to locate lawn mower ID No on a Briggs and Stratton lawn mower
The Model number for the Lawn Mower should be located under the seat or on the underside of the hood. The Model number for the engine should be on the top shroud usually in the front or above the carb.
May 03, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Sport & Outdoor - Others Logo
61 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
