Question about Brother HL 5250DN Laser Printer
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
  • Brother Master
  • 4,338 Answers
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Posted on Mar 18, 2011
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Paper jams after first sheet prints. Tried adding more paper and then taking paper out. Nothing is working. No other sheets are jammed in the printer.
Poor quality paper can cause feed problems as the edge may be poorly sheared causing the sheets to stick together and often leaves fibers on the rollers which reduces their grip. Always 'fan' paper when replenishing to loosen the sheets.
Also, printers with heavy usage will occasionally needs the rubber pickup rollers cleaned. Don't use alcohol since this can dry out the rubbers surface complicating the problem. I have used naphtha to remove the built up paper fibers successfully.
Dec 03, 2010 | Brother HL 5250DN Laser Printer
I have a Brother HL-5150DN. When printing envelopes from manual tray, the printer takes the envelope partially in, and then stops.
if you have done a lot of enevelopes, most likely the pickup roller got paper fibers on the roller and does not have as much traction. try cleaning the roller with isopropal alcohol if that does not help, the roller will be probably need replacing.
Sep 02, 2010 | Brother HL 5250DN Laser Printer
How to you turn on the manual feed for the HL 5250dn?
Simply pull down the door on the front of the machine and insert paper into the manual feed tray. There is a sensor that recognises paper in the manual feed try and will then print from it.
Feb 11, 2010 | Brother HL 5250DN Laser Printer
My brother hl5250dn laser printer won't feed paper. all seems okay other than that.
Make sure the paper guide at the rear of the tray is not set too tight, it needs to be right on the mark for the size you are using. After that you can clean the rubber roller above where the paper sits with a towel damp with alcohol. If it still doesn't feed you may need a shop to check the roller drive gears and clutches.
Feb 05, 2010 | Brother HL 5250DN Laser Printer
Brother HL-1670n failing to feed paper.
I am facing problem for my "Brother HL- 1670N" printer with error E52.
Please help me out!
rj_rrohanjag@yahoo.co.in
Nov 04, 2009 | Brother HL 1670N Laser Printer
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
WHEN PAPER FEEDS THROUGH PRINTER COMES OUT WRINKLED. HL-5250DN BROTHER PRINTER
Try these - is paper dry?
Are you using good quality (80 gsm minimum) paper?
Are the fuser rollers (open back of printer, pull down inner paper guide using projecting lugs) in good shape?
Is there any paper debris in the paper path either before the laser unit or on the final path (look carefully at the little paper separator fingers) that is impeding the paper run at one side?
Does the bypass tray give good or bad results? - if good, look for paper debris in the initial feed path.
Are any flexible plastic guides pulled out of shape to face back up the paper path - often caused by pulling a misfeed out backwards?
I find that paper scraps in the initial feed path can be impossible to see, so I have a piece of laminated paper to push through the feed path. It often finds bits I couldn't see.
Mar 05, 2009 | Brother HL 5250DN Laser Printer
Feeder wheels are spinning backwards
I see that you have mechanicals problem the doublex maybe faulty
i need from you to tray clean the printer all printer roller and tray to disable the doublex future from the driver try to print and send to me feed pack
Dec 05, 2007 | Brother HL 5250DN Laser Printer
Paper pickup problem
check the paper path
check the pickup roller
Sep 06, 2007 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
709 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
