Question about John Deere 22HP VTwin 48" Riding Mower
The main pulley below the motor is split and needs re4placing. I have removed the main bolt but now how do we get the pulley off. I cant stop get the next bolt undun. Do i need to remove the deck?? Thanks Regards **** from West Australia
    Genius:
  • 1,114 Answers
I would recommend that you remove the deck, when you do you will have an adquate amount of work space. You may want a pully puller to assist in getting the pully off.
Posted on Mar 18, 2011
I cant get timing the pulley bolt off to change timing belt?
here is a easy way to do it . pull the starter and lock the flywheel with a screw driver that with stop the motor from turn
Dec 02, 2012 | 2001 Nissan Quest
Trying to replace waterpump on a 96 suzuki swift but cant get the bottom pully off to remove the timing cover to get at the waterpump off. we cannot get a good angle to crack the nut. the frame is in the...
  1. Remove air filter to give you more room to play
  2. Loosen alternator and alternator tensioner. Alternator tensioner bolts to water pump so that bolt will need to come out.
  3. With the alternator loose, the main drive belt should be loose and be able to be removed, do this.
  4. Loosen the tensioner bolt for the air conditioner, on the underside of the engine. Losen the nut on the air conditioner tension wheel. The tensioner wheel should now slide up and down freely, allowing removal of the air conditioner belt.
  5. Remove the 4 x 10mm bolts on the water pump pulley. Remove the water pump pulley.
  6. Remove the 4 x 10mm bolts on the camshaft pulley. This is the main pulley that all the belts connect to. There is a large 17mm bolt in the middle of this pulley that does not need to be removed. (Crankshaft Bolt).
  7. The camshaft pulley should slide off, however you will probably have no clearance (because of the crankshaft bolt) to remove the pulley. The pulley has to be removed.
  8. Place a jack under the sump, use a piece of wood to protect the sump. Jack the sump up 1/2 inch. Undo the two 14mm bolts in the engine mounts. When the two left hand engine mount bolts are out, lower the jack slowly until you can slide the camshaft pulley out.
  9. Remove the plastic timing belt cover.
  10. You should now see the timing belt, remove the timing belt tensioner pulley, being careful not to move the timing belt wheels.
  11. Undo the bolts holding the water pump.
  12. Water pump should come off, water will come out if you haven't drained it.
  13. Scrape off gasket.
  14. Install new water pump.
  15. Reassemble in reverse order.
Read more: http://wiki.answers.com/Q/How_do_you_replace_a_water_pump_on_a_1991_Suzuki_Swift#ixzz1BIA5PNWR
Dec 15, 2010 | 1996 Suzuki Swift
Need to replace the main belt on the bottom of the washer. The belt goes around the drive pulley directly below the electric motor which is accessible from the front bottom access panel. The belt goes...
Unplug the motor wiring, remove the bolts holding the motor bracket (4 I think) remove the hoses from the pump and lift the motor and pump out. Remove the 3 screws on the pump and separate from the motor. Put the belt on the pulley and replace the pump. Slide the motor and pump back in with the belt attached, but don't put the 4 bolts on until you put the belt over the tub pulley. Then put them in and plug the wiring back onto the motor. That should do it!
Nov 20, 2010 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
1999 Buick Park Avenue Water Pump Removal
Hi once you have all the bolts off for the mount raise the front of the motor up till you can remove the center part of the mount
I use a floor jack and a 2x4 across the oil pan then remove the studs for the motor mount bracket now remove the bracket and now you can get the water pump out
hope this helps
May 10, 2009 | 1999 Buick Park Avenue
1999 Buick Park Avenue water pump removal
that is not an idler pully that is the power steering pully if you feel through the holes in the pully you will feel the 13 mm head bolts that hold the pump to the block remove those bolts the pump will drop down and you can then remove the water pump also you have to remove the studs using the inverted torx end on the stud to unscrew it then the mount will come out
May 10, 2009 | 1991 Buick Park Avenue
1999 Park Avenue water pump removal
if thats got the 3800 or 3100 in it your taking out the wrong bolts!!!!!!!
your trying too remove the whole housing
you dont need too do that !!!
take off the 4- 10 mm bolts on the waterpump pully,then remove the bolts behind it i belive that there are 8 of them that takes the pump from the housing!!
Hi,Ihave a hoover hnf 7167 washing machine that my 2 year old turned off then on again while on a 1600 spin(the washing machine,not the 2 year old!!).This caused a loud'pop'and everything went blank.The 13...
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Sep 12, 2008 | Hoover Washing Machines
1998 dodge ram 1500 pick up (not 4wd)
easier on lift if not ramps on ground chalk wheel use stands once all belts are off remove center bolt on bottom crank pulley install crank pulley remover you may have to remove outer part of split pulley thread three puller bolts into bal there should be holes for this snug all three tight install adapter into center where main bolt came out thread tool against adapter as you tighten in the bal pulls out once out replace timing case seal at bottom of cover lightly apply grease or lithium on inside of seal put new bal alighn on keyway install reinstall tool slowly with air ratchet or impact gun reinstall slowly the grease on seal will stop seal from dry start up once bal all the way in install center bolt outer pulley if taken off belts etc
Aug 24, 2008 | 1998 Dodge Ram 1500 4WD
Belt Removal and Replacement
No.  The motor and pump assembly need to come off.
   There is 4 1/2 inch bolts that hold this assembly to the main mechanism.  2 on top and 2 on bottom.  Work belt off bottom pulley on transmission and then remove these bolts.  Turn motor over and remove 3 torx screws holding pump to motor.  Install new belt then reinstall pump with 3 screws.  Reinstall assemblt to mech.  Pu top 2 screws in first then bottom 2.  Be sure belt goes on left side of black plastic idler pulley.  Work belt around transmission pulley.  You can press on opposite end of idler pulley arm to loosen belt tension.  Make sure belt is on all pulleys before testing.
Oct 18, 2007 | Amana ALW480DA Top Load Washer
John Deere 22HP VTwin 48" Riding Mower Logo
85 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
