Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
I have a macbook pro but I can't get to use the drive disc. It allows just "only lecture" how do I do to configure this thing? Thanks
    Sergeant:
    Champion:
  • 239 Answers
I suspect that you may need to download extra firmware for mac - look here
http://support.wdc.com/product/download.asp?groupid=213&lang=en
Posted on Mar 18, 2011
A Imation 4 GB and 4 GB Thoshiba thumb drives could not detected by my MacBook Pro. .
Have you tried plugging these two thumb drives into a different PC than this one? If so, are they recognized?
You have to remember that a MAC and a PC have two very different operating systems and, as such, see things - such as file formats - differently from each other. They are not automatically compatible.
What you have written to those two flash drives on possibly a PC will not necessarily be readable by a MAC computer. And you must be very careful, or you may have a problem trying to put them back into the original computer, if the MAC has scrambled the data.
Cheers!
-a.
May 31, 2012 | Computers & Internet
Software disc is too small, macbook pro will not accept the disc
Hi, if the Macbook can't read the Mini discs, you can copy the contents of the Mini Disc to any USB Flash Drive by inserting the Mini Disc in any Desktop Computer's CD/DVD Drive. After copying the Mini disc contents to USB Flash Drive you can install in the Macbook pro. var geo_Partner = '843689b9-ba30-459d-9c4b-876924715b22'; var geo_isCG = true;
Jun 11, 2011 | Targus Portable USB Notebook Mouse &...
I have a Macbook Air with Microsoft Word Home and Student 2008 installed on it. I use the audio recording feature on in Word to take notes in lectures, but since the internal mic was not enough to capture...
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
Mar 22, 2011 | Apple MacBook Air
Hello, since yesterday my macbook pro is frozen, just don't know how to fix it! My macbook pro was frozen with the apple and grey screen, showing timeclock, so this morning i restarted it with the power...
Take the 2 RAM chips out and make sure they are compatible with your computer and make sure the RAM chips are not broke or defective. Re-insert new RAM chips and make sure they are firmly inserted in their bays. Also, install disc 1 of your 2 disc gray set and hold down C key to boot from disc. Then click on tab for install English. Then go to the top of the screen to utilities and click on disk utility. Now on the left side of screen select your hard drive and then at bottom middle of screen select repair disc. Then when that's done select repair hard drive. Now quit the disc and choose restart from hard drive. See if that don't help ya any. Also, could be bad boot sector in which you will have to save all your data and re-install the operating system. If that don't work, then look into getting a new hard drive and then re-install the operating system. Take your computer into the Apple store and have the Apple dorks look into it if your still under warranty, because you just dropped down some serious cash on this machine.
Nov 04, 2010 | Apple MacBook Mac Notebook
I have macpro 13inc.my problem is my disc is not working with the eject is not function.so still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- CD DVD EJECT -
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
-EJECTING DISC USING TERMINAL-
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
-Mactechtrainer
Aug 26, 2010 | Apple MacBook Pro Notebook
MY Macbook pro disc drive wont read the Starcraft game discs. Every other cd or dvd i put in the drive at least reads, but when I put in starcraft it just spins for a second, pauses, and spins again...
I was pretty disappointed when I couldn't play a 12 year old game on my new macbook either. The best thing to do is go to battle.net, load up the CD key and then load the software onto your mac. The downside is that you will need internet access before playing even if you play single player. That's the way I got around it.
Apr 11, 2010 | Blizzard Entertainment StarCraft Battle...
DVD-R playback on MacBook Pro
I get the same problem... No such solution today!
Jan 22, 2008 | Televison & Video
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
