Question about Hotpoint HSS25GFP Side by Side Refrigerator
I have a side ny side and on the freezer side there is moisture build up on the sides of the wall in the freezer and the food is getting ice cystals on them
  • Hotpoint Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Kenmore elite refrigerator
where is the ice,is it on the food and shelves or is it on the back inside wall of the freezer?if it's on the back inside wall of the freezer you have a defrost problem,bad defrost thermostat,heater,timer or board depending on your model number,if it's on the shelves,door and food packages warm air is getting into the freezer somehow either from the door not closing or the door was left open,could have a bad gasket on the door,the ice chute door could be broke and not closing.let me know what you find and the picture shows a side by side but i'll need the model number too,if it's a side by side or freezer on the bottom the model number should be in the fridge section,on the right hand wall up near the ceiling,if the freezer is on top the number should be on the left side wall in the fridge section up near the ceiling.but with this hot wheather we're having if the door was left open this will happen,you can shut down the machine or unplug it,remove the food from the freezer and melt the ice with a hair dryer,don't do this with the machine running because the hot air will cause the same problem,after the ice is melted you can put the food back in and restart it.
Jul 20, 2013 | Refrigerators
Freezer makes ice, but will not freeze food. control board has been replaced
Is it a side by side? Do you have model number? Was the control board replaced because of this issue? Does the fan motor in freezer operate? Open freezer door and push in door switch to operate fan motor. If it is a side by side sometimes when the fan motor goes bad it damages the motherboard. Is their ice build up on back wall of freezer?
Mar 31, 2011 | GE Refrigerators
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
High temp in food compartent freezer is ok
Try cleaning the dust out from under the fridge and the back. This worked for me
Sep 24, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice build up
Sounds like moisture built up in insulation and may be defrost problem. If you can check inside coil to see if it is clear then moisture is in wall and carrying cold to out side or area is not well insulated. Again hard to tell with out getting into it .
Jun 28, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Ice
it is getting moisture from the refrigerator side.
check closely the door gasket of the refrigerator side, look for cracks and openings and see if it is not sealing properly.
another place to look at is the plastic trimmings around the refrigerator side between teh inner wall and the outside edges.
sometimes they have cracks and openings and moisture could seeped in and makes ice at the lower part of the freezer section.
tnx 4 using fixya,
drcool
Sep 19, 2008 | Refrigerators
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Hotpoint HSS25GFP Side by Side Refrigerator Logo
41 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
