Question about Vacuums
Dyson DC05 buring smell and stopped working. On quick inspection, tiny bits of copper wire inside air filter case. Motor windings possibly burned-out?
Scrapped it!
Posted on Aug 03, 2008
Dco5 burning smell not working
Hi there, it's Jack at Dyson.
If your DC05 is making a burning smell, it sounds like it may be the motor that's at fault. DC05 is one of our very oldest machines, and unfortunately since the start of 2015, we have no longer been able to support DC05 with spares or servicing due to its age. However we do have some discount offers available so DC05 owners can upgrade to the latest Dyson technology if they choose to do so.
If you'd like to find out more or discuss your options with our experts, you're welcome to call us on 0800 298 0298 (UK), or 1800 239 766 (AU).
Feb 10, 2015 | Dyson DC05 Cylinder Bagless Canister...
Excessive noise and smell from dyson dc19t2
It is possible the filter is dirty and restricts air flow which heats the motor due to excess load. The smell could be from overheated motor. Clean the filter if not done recently.
http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc19T2_uk_manual_060710%20pdf.pdf
Sep 02, 2014 | Vacuums
Dyson dc05 electrical fault
Hi Helen,
I'm sorry to hear you're having difficulty with your DC05. From what you've described, it sounds as if the machine may have overheated in use - this will occur if the filter needs a wash, or if the machine has a blockage. You should find the machine will run again after it's had at least two hours to cool down, but to prevent this from reoccuring, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc05/dc05-standard/my-machine-is-not-working/power-failure
If you'd like any further assistance or advice, please give our Helpline a call on 0800 298 0298. Calls are free from UK landlines, and the Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 19, 2012 | Dyson DC05 Bagless Canister Cyclonic...
Motor very loud and not sucking
I am sorry to hear you are having difficulty with the performance of your DC05. Based on your description of the problem your machine may have an obstruction.
Please visit http://support.dyson.co.uk/support/dc05/dc05-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-the-floor-tool for step by step instructions on how to locate and remove an obstruction.
We also recommend washing your filter every 3-6 months. Instructions for washing the filter can also be found on the support section of our website. Please visit http://support.dyson.co.uk/Support/dc05/DC05-Standard/My-machine-is-not-working/Machine-not-sucking-picking-up-as-well-as-usual/Filter-Washing-Video to view the video.
If you need further assistance please call our Helpline free at 0800 298 0298.
Best wishes,
Jessica
Feb 16, 2012 | Dyson DC05 Cylinder Bagless Canister...
I purchased a Dyson DC05 cleaner from a garage sale.The suction is great,however I noticed that the debris does not swirl around in the cylinder when I am vacuuming.I think the suction could be even...
Hi there VacuumGuru from Vacuumspot.com.au here. You will find there are 2 reasons will not spin in a dyson DC05. 1 is that it is missing one of the 2 parts in the dust container, there should be an upside down funnel in there and a rubber boot on it. Without those dust just goes either to the bottom of the bin or to the filter. The 2nd cause is that even though the filters have been cleaned they are simply too old. When you hold the washable filter (the one with the plastic outer and the foam insert) up to the light and take out the foam bit you should be able to see light through the filter. If not you are probably only running on maybe 80% suction which still works but isn't as good as it could be.
The filters are available here if you need them.
Hope this helps! :)
Oct 06, 2010 | Dyson DC05 Cylinder Bagless Canister...
My dyson dc05 just stopped working,any idea what the fault could be? i,ve had it about 7 years
Guessing that the power plug has broken wiring inside the plug--try replacing the plug with an aftermarket plug from the home center or hardware store. Another possibility is the power switch has gone bad--replace it with the proper part ordered from an appliance parts store. Another part that can go bad is the motor brushes, but that requires that the vacuum be fairly well disassembled. Good luck!
Apr 11, 2010 | Dyson DC05 Bagless Canister Cyclonic...
My DC05 does not switch on. I have checked and confirmed the fuse is ok and washed & dried the filter
You can sometimes tell from the "feel" of the switch if this is a problem with the switch itself. However, by far the most common cause of the "won't switch on" problem is damage to the flex. Dysons are often let down by the quality of their flex, and it's quite common for the copper wire in the flex to break (compounded by the fact that the plastic tends to become brittle, especially if the flex has not always been fully unwound in use). This usually happens where the flex is subject to the greatest strain and bending - where it leaves the plug and at the other end which (sadly for a DC05) is inside the rewind reel. There may or may not be visible external signs of damage.
If you want to know what's involved in fitting a new flex and reel, go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC02 cable replacement". The person who set up that site hasn't done a page for this job on a DC05, but the DC02 is similar. His "DC05 motor replacement" page shows you how to dismantle the 05 and get to the cable reel.
I hope this helps. Good luck!
Feb 14, 2010 | Dyson DC05 Cylinder Bagless Canister...
How many filters does Dyson DC05 has?
The DC05 has two filters.  In terms of air-flow through the machine, one sits between the bin and the vacuum motor, the other is after the motor and is effectively the exhaust filter. The one that's missing on your machine is the first filter - it consists of a blue foam disc contained within a yellow surround (the base of the surround has additional filter material built in to it). Both components are washable (but be sure everything is absolutely dry before re-installing after washing).  The filter you can see under the bin is the second (HEPA) filter. This one is usually quite long-lived but, if your machine has been used without the first filter in place, the HEPA filter almost certainly needs replacing too.  The machine should never be used without the first filter in place, as that will risk serious damage to the motor and will certainly shorten its life.  Incidentally, user manuals can be downloaded from dyson.com.
Jun 05, 2009 | Dyson DC05 Cylinder Bagless Canister...
Not sucking up
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34218&thid=565461
Not sucking up
Posted by Smudge935 on May 02, 2008
Hi, I have a Dyson DC05 and initially it sucks up ok then stops. On investigation the dust particles are ending up in the pre-motor filter instead of the canister.
I have checked for blockages, and cleaned filters. Any ideas????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Something is blocking the path of the dirt to the canister and it should not be going directly to the motor filter (diverter valve) that is supposed to be a backup just in case. So that the motor does not burn up, please check with you local vacuum cleaner dealer for a schematic or a product breakdown.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
questions@dyson.com
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Dyson DC05 Cylinder Bagless Canister...
DYSON DC05
My friends Dyson DC05 was loosing suction and then it stopped altogether one day. When she took the filters out there was black soot in them so it was obvious that the motor had burnt out. I think this happened because she wasn't cleaning the filters regularly (go do yours now!) I replaced the motor myself and wrote a guide with photo's at www.tasweb.org
Dec 11, 2007 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
60 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
