Question about Sony Audio Players & Recorders
SONY SUBWOOFER SA-WMS7 ONLY NOW WORKING ON MUCH REDUCED VOLUME - ANY IDEAS PLEASE?
3 Suggested Answers
early1234
  • 871 Answers
SOURCE: sony sa-wx90 subwoofer
thats called electrical recoil, the energy that is stored bursts out thru your subs therefore you hear your subwoofer bang.
i suggest you clean your wirings.
hope this helps.
Posted on Jan 14, 2008
SOURCE: SONY SA-WM500 SUBWOOFER
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Posted on Sep 25, 2008
Panasonic sa-vk800 when the volume up the unit is shoot down than display f16
Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
Dec 15, 2014 | Panasonic Sa-ht70 Home Theater Receiver 5...
My Sony SA-WM40 subwoofer has power, but sound kicks out. I'll turn off power for about 5min and when turn power on, sound is back. Is something overheating?
Probably, or the woofer coil itself is experiencing a heat, volume or motion related short. Clean any dust or debris from the heat sink fins in the back. Make sure it has lots of space for cooling ventilation.
Mar 31, 2011 | Sony SA-WM40 Subwoofer
My Subwoofer Sony SA_WM500 was always burn the fuse therefore I had to change the STK, but now it takes off sound very low, How can I have back the high sound level? Zaruque Quimuenhe
It's no clear what you mean by "I had to change the STK", but if that means you have somehow defeated the fusing or place a larger fuse than it requires then STOP and shut it off. You might be risking a fire or more serious damage to the amp.
I would recommend you find a hands-on tech to look at it.
If you have resolved the fuse problem and now just have low subwoofer volume, you might want to track it back to the source and ITS subwoofer volume setting. There IS a volume level control on the sub, too. Turn it up.
The manual is here:
http://www.retrevo.com/support/Sony-SA-WM500-Subwoofers-manual/id/752ag404/t/2/
Jan 11, 2011 | Sony SA-WM500 Subwoofer
The speaker is starting to buzz during the low
It probably buzzes all the time, you just notice it when it is outputting little volume. Check the cables for loose connections or replace them with other cable as a test.
Mar 08, 2010 | Sony SA-WM40 Subwoofer
I need the System Control Cable for my Sony SA-VA100 Speakers!
Need the System Control Cable to a Sony Sa-VA100
Jun 22, 2009 | Sony SA-VA100 System
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
Terrible distortion from Sony Dav-x10 2.1 subwoofer
its not broken just turn the cut off frequency to level and the volume of the sub lil bit higher and it should work fine.
Nov 11, 2008 | Sony SA-W305 Subwoofer
Sep 25, 2008 | Sony SA-WM500 Subwoofer
No Output Subwoofer
hi, ya , some recievers have its setup where u have to enable the sub out,, check the menu carefully, also the player menu if the sub is on or off, let me know..
Jan 10, 2008 | Sony SA-W305 Subwoofer
384 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
