Question about AKG C4000B Professional Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
  • Jon Kelly Apr 15, 2014
    To update, one of the 3 connections to the diaphragm was broken. I resoldered it, now the mic works as it should.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Posted on Apr 09, 2013
Hello folks, so I am working on a 2000 bravada in my free time. Haven't gotten into the engine yet but I need parts first. I just wish to know if it has a carburetor
Hi Clayton, The motor doesn't start so It's either fuel OR electrical thats stopping it, First check spark plug... Pull spark plug out and visually inspect for any dirt touching both electrodes... Next, Plug the spark plug back into the spark plug lead and earth it to the motor(make sure the spark plug is touching metal)then try turning the motor to see if the spark plug sparks...If it does spark then it's a fuel problem. You need to pull your carby off and unscrew the bottom half from the top, 1st sign of a needle stuck inside the seat is a dry carby There you'll find the float, push the float up and down and see if the needle above the float slides up and down from the seat, If the needle stays up then it's stuck and NOT letting the fuel into the carby, Just pull it down with your fingers to loosen it up and spray up the seat with a carby cleaner. Also the link below is a short YouTube video showing the right colour spark and it should spark over the top of the centre electrode, I hope this helps.... CHEERS..
How to check for Spark Plug Fire in any engine
Apr 29, 2016 | Garden
Humming noise when guitar is turned up
Humming noises are normal a sign of a bad earth. It could also be that you have a faulty pickup or volume/tone control.
Does the hum stop when you touch various metalwork, socket cover, strings, bridge for example. If it does almost certainly an earthing problem.
Nov 09, 2015 | Music
Hi. My Magnum Omegaforce has a hum which comes from the speaker, but only when I plug the mic in. If I put the mic down there's no hum. If I pick up the mic or put my hand near it the hum...
Sound like the radio is looking for a ground. I would tell you to take it to a good CB Shop,not all shops work on this radio so be careful and ask them first.But you're touching it or almost touching it is giving it a "False Ground" causing it to hum.
Jul 03, 2011 | Magnum OmegaForce S45 CB Radio
Galaxy dx99v, bad squeal when I key the mic
Your microphone wires may be shorted take the mic plug apart (small screws) Now check for frayed wires touching or twisted together!
With the wires being resolderd or taped apart put back together
with the U pointing downward you shout have :
Right corner bottom Sheild ground!
Left corner bottom Black recive
Right corner top White or yellow this is Audio wire
Left corner top RED Transmit or PTT wire
If wiring looks good the problem is in the Mic take to servicer!
May 09, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
HUm problem. Worse when touching outside of mic.
Hello
Check the grounding wire on the mic itself, this is where the problem lies, cause when you touch it, the grounding follows an alternative path through your body, that is why the humming increases when you touch it.
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 12, 2009 | Computers & Internet
Flotech utility pump clogged. took top off and
unless you are a electriciani would highly recommend you do not touch this... the green wire is a earth and the two other wires are your active and neutral if you wire this back to front it will spin the oppisite way and could cause internal damage to the pump could spin impeller off or worse...
Regards
Brad:)
Sep 21, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Satellite Pro microphone has hum in background when recording
Usual cause of mike hum is poor earth of screen in cable. Check connections between cable and earth pin or shell of plug. Don't make earth connections at both ends of cable as this will create a loop areal and pick up electrical noise.
You might also want to check for poor amp earthing. Normally moving close to, or touching, the front panel will reveal this problem as hum will reduce dramatically.
Sep 21, 2009 | Toshiba Audio Players & Recorders
Mic does not work
Its not unusual for the mic to stop working, its n easy replacement. you will need to open the top and bottom halves of the case. The mic fits in the top part then the wire goes through the hinge to the motherboard in the bottom half of the case. No soldering just plug it on.
Jun 30, 2009 | Nintendo DS Lite Console
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
AKG C4000B Professional Microphone Logo
122 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
