Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
When power supply off and comes back i manually switch on from remote.i want it auto on
  • Mitsubishi Master
  • 43,501 Answers
Unfortunately with those units they will not automatically restart...and you annot set them to restart automatically... it is a pain I know...have had many complaints about that and told the Mitsubishi Rep. that it is not good...
heatman101
Posted on Mar 18, 2011
Why wont the flashing red light go away and switch on my 32 inch led hisense tv
It could be your remote control batteries are dead? Try to manually depress on/off switch on TV.
Dec 03, 2014 | Hisense Televison & Video
I have haier split air condition Hsu 18ck03 When power supply off and comes back i manually switch on from remote.i want it auto on
Your air conditioner is not a inverter model(your model is it a low cost model )and doesn-t work automaticlly when the power is off
Aug 01, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
"I have LG 37LC2D TV,when I turn the power on remote controlled or manually it immediately powers off. Is this an issue with the on/off switch inside the tv and how can remedy the problem?"
I have an LG as well.
My troublshooing says:
"Check the power control setting.The power supply may be interupted.
Check if the Auto sleep feature is actiated in the Time settings.
Refer to the " Sleep timer".
If there is no signal while the TV is on, the TV will turn off automatically after 15 miutes or so"
Feb 24, 2012 | LG 37LC2D Television
Replaced smoked RaidmaxKY-520ATX power supply. Replacement power supply does not turn on. Which wires are remote power up from mother board ?
You can actually test the power supply before connecting it to the motherboard. Take a look at the power supply pinout by CLICKING HERE. Jump pin 14 with 13, 15, 16, or 17 to turn it on. You will have to get a manual for your motherboard to see how the front panel connector is configured with your case power switch. If you have that manual you can jump the 2 connector pins for the power switch to test the p/s from the motherboard.
Jun 03, 2011 | RaidMax (KY-520ATX) 420-Watt Power Supply
Unplugged tv and when plugged back in doesn't come on
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Apr 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Our LT42DV8BJ JVC tv went off and wouldn't switch back on
This my be the power supply board. Capacitors will get leakey and wont let the set start up.
Jul 24, 2009 | JVC Televison & Video
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
A/c will not come on with the remote or manual bypass
Blinking led in the unit means some error or defect in the unit. It stops the remote control from working to protect the unit from operating with defective parts to avoid severe damage to the unit.
Try to reset the unit by disconnecting the power supply for 10sec. then on the power supply again and test. If it wont work then there are some defective parts in the unit that need to replace.
Jan 20, 2009 | Coleman Mach III Air Conditioner
Kenwood Power Supply Dip Switch Setting
why don't you get a controller for that supply? I got one...
John
Jul 08, 2008 | Kenwood (PDS36-20) Power Supply
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
182 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
