Question about Toshiba TEC B-572 Printer
My tec 572 printer is displaying an error msg. 0009,2971-1588? Can anyone help me?
    Champion:
  • 254 Answers
Syntax error;
Wrong size of labels or wrong graphic types
Posted on Aug 16, 2011
How do I perform a test print on a Tec B-572 printer?
I'm sorry for late answer.
Just turn it off, Hold feed button for 5 secs while you turn it on again
Jan 31, 2013 | Toshiba TEC B-572 Printer
My TEC B-572 Printer is sporadically displaying various error codes.
Two things:
If firmware prior to 3.1 the you should not use topix graphics
You can use ascii or compressed. If you use topics and the printer doesn't understand it then the line is displayed with error condition.
Else you have a bad monitoring of the spool. B575 has monodirectional centronics port.
Jan 11, 2012 | Toshiba TEC B-572 Printer
My toshiba TEC B-572 prints but it does not print evenly on each tree tag/label. it starts at the bottom of one and ends at the top on the last one. it stops cause it says that it is out of media. I...
Its not out of media, the issue is calbration, this printer will need to be physically serviced to have it work correctly again. Thisd out of media is a sensor that has malfuctioned and thus reporting this error to you.
I know I am probably telling you what you already know, but actually thisd item would need physical repair. if I get a zip code I can line you up with a Tech in your area.
Oct 07, 2011 | Toshiba TEC B-572 Printer
TEC B 572 WHEN USING DATA TRANSFER SWITCH BOX.. ERROR CODE SG;0040,1120,1384,00 APPEARS ON 1 MACHINE.
This may be a firmware problem! or problem on the communication port
This is a syntax error detected by the machine
Aug 01, 2011 | Toshiba TEC B-472 Thermal Label Printer
Printer display various error codes when switched on ie ?d????.'//;
You have a problem with data transmission.
May be due to cable problem or centronics interface.
Check using serial cable default 9600,n,8,1
Oct 15, 2010 | Toshiba TEC B-572 Printer
TEC B-572 printer, labels off center.
Check the alignement of the media guide. and the alignement of the print head. + X adjust parameter
May 15, 2010 | Toshiba TEC B-572 Printer
Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Mar 19, 2009 | Toshiba TEC B-572 Printer
You should recalibrate your sensor without or use reflective sensor instead of transmissive.
Jun 12, 2008 | Toshiba TEC B-572 Printer
Toshiba TEC B-572 Printer Logo
201 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
