Question about HP LaserJet P3005 Printer
Where can I download the latest Firmware upgrade for the HP LaserJet P3005 printer. I am unable to locate it on the HP site
  • 186 Answers
Doesn't look like there is any firmware updates it would be posted on the site you could check if HP Easy Printer Care Software has any options for firmware upgrades.
Posted on Mar 18, 2011
Hp laserjet p2055dn blank display
Similiar Blank Display solution from HP web site:
HP LaserJet P3005 Printer Series - Blank Display
ISSUE: Printer has a blank display.
SOLUTION:
Check if the printer is connected directly into a wall outlet. If not directly connected, power off the printer and connect directly to wall outlet.
Disconnect any local or network connection from any device and keep the printer connected with the power cord cable.
Power cycle the printer. If the issue persists, continue with step 4. If the printer powers up to READY, perform the following steps:
Print a configuration page and check the firmware version. If the printer does not have the latest firmware version, upgrade the printers firmware. Click here to see the latest firmware available for your printer at www.hp.com/go/support . Select Download driver and software (and firmware) and type in the product name or select the product from the product category list.
When the firmware upgrade is completed, power cycle the printer and print a configuration page again and check firmware date code, (it should change to the latest version) then power cycle the printer again.
If the printer powers up to READY, plug the local or network cable back in and print a Windows test page by printing from any application.
If the issue persists, continue with step 4 below.
Remove any additional memory DIMM installed (usually the LaserJet P3005N, DN and X come with a 32 MB memory DIMM installed), and any Internal EIO card or internal hard disk installed and then power cycle. If the issue persists, continue with the next step.
Perform a cold reset:
Turn the device off.
Turn the device on. When the memory count begins, press and hold the check button. Continue holding down the check button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds
After the message SELECT LANGUAGE appears on the display, press the arrow up or arrow down buttons until COLD RESET is highlighted.
Press the check button. The device performs a cold reset and then continues its power-on sequence.
If the issue persists, continue with the remaining steps.
If the printer powers up to READY, test the printer functionality by printing internal pages. Plug the local or network connection in and test the printer from the workstation.
If the issue persists without any internal device installed, the printer will require service.
Contact HP support.
Click here for information on contacting HP support at welcome.hp.com/country/us/en/wwcontact_us.html.
HP LaserJet P3005 Printer Series Blank Display
Apr 09, 2016 | HP Office Equipment & Supplies
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
49.4C2D ERROR HP P 3005
49 errors are normally Firmware errors. 1st try to print from a different application. If you still get the error go out www.hp.com/support After answering the question go to the drivers and look for the firmware downloads. Download and install the latest firmware. Make sure that you follow the directions. And don't touch the printer until it reboots.
Aug 19, 2011 | HP LaserJet P3005 Printer
49.2F9D Error Turn Power On/Off
Visit www.hp.com/#support and find the latest firmware for your printer. Download it and install it. Follow all the directions.
Feb 01, 2011 | HP LaserJet P3005 Printer
Downld file now SEND RFU UPGRADE
It means that the firmware is hosed and you have to upgrade the firmware.
Go to www.hp.com/#support
select 'support and drivers'
Enter your printer model
Select the correct printer model
Select 'software'
Select 'firmware'
Read all the directions, do exactly what is says, and don't touch the printer while it is installing the firmware.
It really isn't hard to do.
Jan 28, 2011 | LaserJet P3005 Printer
My printer hp lj 3005 in error code 49.2f9d please solve my problem
49.XXXX is a critical firmware error. It may be caused by a bunch of things such as bad input data or data corruption due to poor cables.
From the service manual :-
Recommended action
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
Hope this helps
Dec 29, 2010 | HP LaserJet P3005 Printer
MY HP LJ 3005N PRINTER GIVING 49.2F9D ERROR
Firmware upgrade. www.hp.com/go/ljp3005 firmware
Do it twice. Upgrade the firmware and then do it again. Don't ask.
Oct 13, 2010 | HP LaserJet P3005 Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
Laserjet P3005
Firmware needs to be updated by a HP technician.
Feb 13, 2009 | HP LaserJet P3005dn Printer
Firmware for HP Laserjet 1220
try searching limewire or kazza you may get lucky with somebody shareing a download you need
Dec 14, 2007 | HP LaserJet 1220 Printer
HP LaserJet P3005 Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
