Question about Hasbro Playskool Tonka Interactive Rumblin Chuck
I cannot find the battery compartment i opened the one underneath the truck but i saw wires and voice box and not the batteries where is it located thanks
    Sergeant:
    Champion:
  • 239 Answers
Instructions here
http://www.hasbro.com/common/documents/65c5d959cc8845269954593b0fdc2d18/D193402D19B9F36910D3948E2C70DA47.pdf
Looks like there is a panel (at the back?) which you need to undo. Takes type C batteries (4)
Posted on Mar 18, 2011
The gray part on the back come off, it have two screws in it. Unscrew that I cannot find the battery - c1740fd3-c552-4181-8ec4-5f6376026834.jpg
Posted on Jan 29, 2014
Where are the fuse boxes on fiesta zetec s petrol 2009
Fuse box is located in the glove compartment. Empty the glove compartment, then the side will pop out for access to the fuses.
Aug 28, 2014 | 2010 Ford Fiesta 1.25
Saab 9 7x fuse locations and descriptions
We have 2 fuse boxes. One in the engine compartment just behind the battery. Top of cover has descriptions. The other one is underneath the rear seat.
Oct 02, 2013 | Saab 9 7X Cars & Trucks
I have a S 4.0, car has been sitting in garage for 1 year. New battery installed but only drivers side window, and power seats work. No crank, no lights, wipers or any other acc's. I have checked the...
Look in your owner manual for the 3 fuse box locations. It is similar to our Lincoln LS.
From LS owner manual.
There is a 175 amp mega fuse in the wire harness near the luggage compartment fuse box. In circuit with Red/Blue wire.
Front power distribution box
The front power distribution box is
located in the engine compartment.
The power distribution box contains
high-current fuses that protect your
vehicle's main electrical systems
from overloads.
Passenger compartment fuse panel
The fuse panel is located on the right hand side kick panel. Remove the
panel cover to access the fuses.
To remove a fuse use the fuse puller tool provided on the fuse panel
cover.
Rear power distribution box
The rear power distribution box is
located in the luggage compartment
under the spare tire well cover. The
from overloads.
Jun 08, 2011 | 2000 Jaguar S-Type
I bought my wife Conair massaging slippers model VSW32. There was no instruction manual. I need to how to install the batteries. Can you help
Underneath the pink inside sole is a box for the battery. Pop the plastic cover with a small screwdriver. Install 1 "AAA" battery in each slipper and replace plastic cover. The button to turn the massage off and on is on the side of each slipper on the outer sole.
Dec 25, 2010 | Clothing Accessories
Where is the ac drain hose
Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -- open the driver's door
-- locate where the air conditioner blower box is attached to the passenger side of the firewall – see photo #1 – look to the immediate right at the top of the gas pedal arm
-- condensation flows toward the front of the vehicle through the firewall at the leftmost edge of the air conditioner blower box – drain channel
-- open the hood and stand next to the front wheel on the driver's side
-- look down at the firewall over the battery and to the passenger side of the brake master cylinder – see photo #2
-- locate the small diameter metal tubes running horizontally and attached to the engine compartment firewall
-- locate the hole in the engine compartment firewall panel behind the small diameter metal tubes
-- this hole leads to the drain opening in the air conditioner blower box mounted in the passenger compartment
-- follow the brake tubes as they run from under the vehicle and turn toward the front wheel on the driver's side
-- locate the hole in the engine compartment panel behind the brake tubes
-- insert a short length of stiff wire into the hole through the engine compartment panel to unblock the drain hole
Jul 11, 2009 | 2004 Mitsubishi Endeavor
Battery drains with everything shut off car battery is good.
Have you checked the battery saver relay? It's located in the passenger compartment fuse box underneath the driver's side dash panel (it's just underneath the steering wheel). The lid will tell you which component it is. Relays are about $10.00 at autozone, so you can just pop the new one in if you want, or take it out and test it with a volt meter. If you want to test it, let me know and I'll post instructions.
Jun 28, 2009 | 1999 Ford Taurus
2004 VW Jetta engine compartment fuze box location
one is located over the battery, the other is located in the side of the dash.
First panel:
If you pop your hood the battery will be on your right sid in the front of the engine bay. There is a small rectangular piece on top of the battery with a lot of heavy guage red wires going to it. That is the engine bay fuse box.
Second panel:
if you open your driver side car door it's under neath a panel located inbetween the door and the dash board.
Apr 27, 2009 | 2004 Volkswagen Jetta
Hasbro Playskool Tonka Interactive Rumblin Chuck Logo
1,645 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
