Question about Lomo Action Sampler 35mm Point and Shoot Camera
On my action sampler lomography, when i got the pictures developed most just had one picture and the rest were black. also it sometimes makes a noise up to 20 minutes after i have taken a picture. does that mean it has a slow reaction and takes a picture of the inside of my bag 20 minutes after i took the picture or something? thanks in advance!
4 Suggested Answers
SOURCE: Image Problems
the film is pulled by gears as u click and wind..one gear tooth broke inside camera body causes weird things like u said and then catches to move around to get the clich again. dont know if gear is plastic or metal I read on internet some metal gear replacements....try looking there. really not sure but i think im in the ball park. CrazyLarry
Posted on Jun 27, 2007
Obertelli
  • 3006 Answers
SOURCE: How do I get my
Turn the thumb wheel located behind the shutter release button until it stops at the next frame.
Note that on your model the MX button (Multiple eXposure) to the left of the thumb wheel often gets stuck and prevents the film from advancing. The button should be firmly to the right when not in use. If the MX system is broken there's nothing you can do as the parts cannot be repaired or replaced. All LOMO and Holga models are extremely cheaply made plastic "toy"cameras and are not designed to last. Most have a maximum design lifespan of ten to twelve rolls of film, the FishEye model is designed to last just half that. It's only in Western countries that these models sell for ridiculously high prices, as an example my Lomo FishEye cost me 48 Hong Kong Dollars (that's just under GBP£4 or just over US$6). Back home in the UK they sell for ten times more.
The above explanation is not meant to be disparaging about your camera, but is just to illustrate that these cameras are really built from the start as disposable cameras which have the added bonus of being reusable a few times so cannot usually be repaired when broken.
Posted on Oct 11, 2010
SOURCE: hi, well firstly, my pictures
I have the same issue with the borders being black , i think its because the 24/24 setting ie square shot is selected and the developers print on rectangular paper ,I may be wrong. On the bluring have you changed the focus on the front or have you got it set on B as both may have this effect . hope it helps
Narbs
Posted on Jun 17, 2011
Hi, when I take photos by my recesky there is always white small area at the left side of the photos.
Ah,the joys of lomography! You apparently have a light leak somewhere on the right side of the camera. If there are any joints, try covering them with black electrical tape and shoot another roll to see the results.
Or learn to enjoy the sometimes-unpredictable art of lomography.
Nov 16, 2016 | Cameras
Dear Sir, I have the same model, very nice pictures, but lately the pictures sometime it flickers and the are horizontal broken lines. Sometimes it is perfect. Kindly advise- T.Q - DAG
Turn off the plasma TV, wait for 10 minutes then turn it back on. Sometimes during first installation, the television can develop vertical lines. These lines are usually not the television but noise from a secondary device. This action will fix 50% of the plasma TVs out there.
Check secondary devices. Make sure they are disconnected and turned off. Secondary devices can cause noise in your TV, creating these annoying lines. A good example is the lines you see when you turn on your blender. Malfunctioning secondary devices can generate these lines.
Check your cable connections. Make sure that your coaxial and HDMI cables are connected properly. Bad connections can create noise in the television and cause these lines.
Go to your television's support website and download the latest version of the firmware. You can do this by transferring the program to a flash drive then using that flash drive to update your TV. There are corrective measures inside these firmware updates for the most common problems like vertical and horizontal lines. You can then put your flash drive directly into your television's USB port and update your firmware from the television setup menu. Once this is done, the vertical lines should disappear.
If they don't, then it means a display panel is failing. If that's the case, it may be cheaper to replace the whole TV, rather than just replacing the panel
Jun 05, 2014 | JVC PD-42V475 42 in. HD-Ready Plasma...
My Samsung HLN4365 tv made a loud popping noise then the picture went to black and white with a lot of interference in the screen. Also now makes a loud humming noise sometimes
You are likely to have developed a bad color wheel. Do a search on Ebay with your model number or Google the model number. This will give you a heads up if you get a TV tech to fix the set
May 20, 2011 | Samsung Televison & Video
The screen boots up with the commands and then it
The picture board on your monitor is faulty or bad, since it goes black after booting, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
My action sampler doesnt work properly.. i have loaded the film and shoot correctly, i guess :d but the result is not in four panels, but just like an usual film cameras (in 1 panel only).. what's wrong?...
The problem is your lab, assuming you got prints, the lab printed them like normal, But look at your negatives, you will see the 4 panel images.
Best to print an Actionsampler photo from the internet or lomography website, just print a rough one on regular paper, 4x6inch, and take it to the lab to show them how the prints should be. They should re-print from your negatives for free because they made an error the first time. It may have been an automatic adjustment by the machine they use.
Dec 19, 2009 | Lomo Action Sampler 35mm Point and Shoot...
The shutter button does not appear to click down and the lense does not open so no picture is taken. Usually it makes a sound and you know the picture has taken. HELP MEEE????
I had a similar problem with another brand of this type of camera. I would click the shutter and hear it open but it would not go through the series of four lens exposures unless I manually turned the film advance wheel . I think it may be because the motor isn't strong enough to draw the film across and trigger the shots. cheap plastic, ya know. I never got the film developed but im interested to see if it got anything at all.
Oct 28, 2009 | Lomo Action Sampler 35mm Point and Shoot...
My camera's flash is flashing 2 times prior to
The Flashing is a normal thing for the Camera to do, Nothing to worry about.
Oct 04, 2009 | Canon EOS Rebel XSi Digital Camera
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
No pictures at all, at it's best just blury colours
got my developed film back and all I got were pictures seperated into 4 boxes with one colour a box. can you explain more can you look at the negatives and see whats on them. try a sunny sixteen rul on a sunny day with sun high in sky set camera aperture to F16 if you are using ISO100 film set the camera shutter to 1/100th ISO 200 = 1/200th etc take a picture of a stationary subject - like a brick wall whats the make and model of the camaera
Apr 13, 2007 | Lomo Action Sampler Kit Camera 35mm Point...
Lomo Action Sampler 35mm Point and Shoot Camera Logo
47 people viewed this question
Top Lomo Cameras Experts
Steve
Are you a Lomo Camera Expert? Answer questions, earn points and help others
