Question about Dryers
Dryer won't get hot. Vent line is clear. Turns and blows fine, Just won't get get hot? Todd Tomazic (714) 390-0971
  • Dryers Master
  • 43,501 Answers
Hi Todd,
As near as I can tell you did not identify whether you have a gas dryer or an electric one...the reasons why a dryer will not heat are different for the two types...
Here are a couple of tips that I wrote that will give you a bunch of info to get started on for both types...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 18, 2011
Clothes aren't getting dry
Check your vent hose and where it exits the building, clean away all lint anything blocking the vent cap or in the vent hose. Remove the vent from the back of the dryer and make sure it is all clean and clear there and make sure the betn is not kinked up when putting the dryer back into it space. Now before you blow me off, if any of this is true for your dryer the heat will build up and trip the thermostat causing it not to heat properly and the blower wheel can not move the air to collect the moisture and remove it from inside the dryer. Also, any sagging vent line can collect moisture which turns to a puddle of water in the line and this to will not allow your dryer to dry the clothes. Good luck I hope I have helped you.
Mar 30, 2014 | LG Tromm Electric Dryer
Mdg7600 gas dryer replaced coil- hot surface igniter lights then shuts off -bypassed cycling thermostat still no luck
if it lights then most likely you have a block somewhere with lint,pull out the lint filter and then remove the duct that the filter slides into and clean it out,with a shop vac set it up to blow and blow off the burner tube,the motor and the whole cabinet,put it back together,now go to the back,remove the vent line and start it,if it runs fine until you reinstall the vent line then you have a block in the line,i use a leaf blower,i remove the vent line,go outside,make sure the outside duct is clear,nothing blocking it like a cage or screen,go back inside,stick the leaf blower into the vent line and blow it out to the outside,this usually clears it.lint buildup is the most common problem with dryers.let me know what you find.if you already changed the gas coils and ignitor and the flame does light most likely bad air movement.
Oct 10, 2013 | Maytag Dryers
My LG Tromm electric dryer won't heat - again.
if the high limit is popping the dryer is getting to hot,i know you say you checked the vent line but i've heard that before,when i get out i remove the vent from the back of dryer,change out the t-stat and run it with the vent line off and it runs fine,how long is the vent line?if it's a long run remove it from the back of dryer and stick a leaf blower into it,blow it out to the outside and see what comes out,also first run it on air fluff,if this is a newer dryer set it to timed dry and then you can set it to air fluff,go outside and feel how it blows,then after you blow it out check it again,if you see alot of lint blow out and it's blowing harder your all set,you should take the dryer apart and clean it and the vent line once a year and you won't have any problems like this,also you won't have to worry about a dryer fire,your clothes will dry on time and less parts will have to be changed out,also when you get it to heat again run it on air fluff,if it gets hot on air fluff you have a shorted heater,one of the coils are touching the metal box on the heater and the heater won't shut off,also you have to clean out the duct where the lint filter slides down into,if this is blocked the dryer can't push the air out the blower wheel is blocked with lint.hope this helps you out happy holidays
Dec 25, 2017 | LG Tromm Electric Dryer
KEEPS BLOWING THERMOSTATS
usually the thermostats blow when the dryer runs to hot so you don't have a fire,most likely the dryer needs to be cleaned out and the vent line has to be cleaned,you didn't send the model number or brand name so do this,unplug the dryer,you have to remove the filter and clean the duct that the filter slides into,most of the time you have to take the dryer apart to do this right.then blow out and vac all the lint in the cabinet where the motor is.now go outside,make sure the vent is open,if there's a cage on it or screen remove it,all it does is block the lint and then the air can't blow through building up lint in the line,i take the vent line off the back of the dryer,stick a leaf blower in it and blow the line out,i've had people say the line was clear,i go there,blow out the line and on two occasions i blew out birds nest.when the dryer is clean,change out the thermostats that are bad and you'll be fine
Mar 10, 2011 | Dryers
When I turn on the dryer, the top gets VERY hot within about 2 minutes. When I look inside, you can see the heating element is red. I checked the vent and it is clear. I did notice that there was some...
if the lint is damp then the air isn't moving out the vent line,unplug the dryer, go outside and make sure the hood is clear, then go back inside and remove the vent line from the back of the dryer,if the vent line is long i use a leaf blower to blow out the line,just stick it into the vent line and blow it so all the lint will go outside,if you could have someone watch the outside and they can let you know when the line is clear,also the duct that the lint filter slides into should be cleaned out and you should vacuum out where the motor is,you have an open flame inside the dryer and the lint can and will catch fire if it's not cleaned out,i do this to my dryer once a year,the clothes dry on time,no fires and the parts in the dryer last longer from being cleaned and the dryer isn't overheating and damaging the motor and other parts from running to hot.let me know how you make out
Oct 29, 2010 | GE DVLR223 Dryers
Dryer runs and drys cloths but dosent cool down and stop
when was the last time you cleaned out the dryer?unplug the dryer,remove the bottom panel,take out the lint filter and remove the duct that it slides into.clean the duct out,vac out the inside of dryer,if you have a shop vac you can put it on blow and blow the lint forwards so you don't ha ve to remove the drum.put that back together and remove the vent line from the back of dryer,if it's a long run blow it out with a leaf blower,also make sure the outside vent is clear before you blow out the vent line,if the dryer can't move the air around it will run hot.
Jun 26, 2010 | Kenmore Elite HE4 Electric Dryer
Will dryer still run and heat if one of the thermostats (cycling[internal bias], high limit, and/or thermal cut-off) is faulty? Would it simply 'blow' the thermal fuse (that i just replaced) again?
if the thermal fuse keeps blowing it's because the dryer needs a cleanout.you need to clean out the duct that the lint filter slides into vac out the inside of dryer where the motor is and if you have a shop vac put it on blow and blow off the motor,there's alot of lint stuck inside it that the vac can't get out,you can blow the lint from the back of dryer to the front so you don't have to pull the drum to clean it.if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean out the line,i've blown out bird nests and big balls of wet lint after people told me the vent line was clear also make sure the outside vent is clear no screens or cages if there is remove them all they do is catch lint.do this once a year so you don't have a fire and you won't have to replace parts from overheating,thermal fuse is a safety that will pop if the dryer runs to hot mostly from a clogged dryer
Apr 17, 2010 | Kenmore 62882 Electric Dryer
How hot should a gas or electric dryer get, mine seems too hot
if the dryer is running hot it's because you haven't cleaned out the dryer?try running it with the vent line disconnected from the back of dryer,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to blow out the line,make sure the outside vent is clear first,no screens or cages in the way,if there is remove them all they do is catch lint,next unplug the dryer,clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is,if you have a shop vac that blows on one end blow off the motor and blow all the lint from the back of dryer to the front so you don't have to remove the drum,do this once a year and you shouldn't have to many problems with the dryer
Mar 20, 2010 | Amana DLE330RAW Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer
Disconnect the vent from the back of the dryer and dry a load unvented too make sure you don't have lint built up in the vent line causing an air flow restriction.
Jul 30, 2008 | Kenmore Dryers
Dryers Logo
13 people viewed this question
Top Dryers Experts
