Question about Dewalt DC925 Cordless Drill
I HAVE A MODEL DW004 24V CORDLESS HAMMERDRILL THAT HAS STOPPED HAMMERING. IT ONLY RUNS IN DRILL MODE NO MATTER THE SWITCH POSITION. ANY IDEAS ON WHAT COULD BE WRONG. SWITCH APPEARS AND FEELS INTACT.
  • Bubba Turner Mar 18, 2011
    Is the bit securely seated in the chuck? Does the drill itself feel like it is hammering, i.e. when you move the function switch from drill to hammer, does it feel any different when it is running?
    President:
  • 1,796 Answers
Hi!!
The hammerdrill function is set by the selector switch, the switch itself may look fine from the outside, but, if it is not switching functions, you should open the hammerdrill and check the switching mechanism, even if you don't have an idea of how it works, after a visual inspection to the switching mechanism, common sense will tell you what's wrong, it is actually pretty simple.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Mar 18, 2011
Need on and off switch for Thor Champion 1/2 electric drill Independent Pneumatic tool company
you mite not get the original one, but you get a similar switch which looks alike, in the ebay
May 28, 2014 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
I have a Dewalt DCD770KL 18v LiOn drill/hammerdrill. I did not use it much for drilling into concrete before, but recently, I needed to mount something to the ground. I used the hammerdrill setting and...
Please visit a qualified technician. Because it's also my personal experienced with hammer drill that inside a small ball bearing with tiny spring as a tosser for shifting always been stocked up by sticky or hardening grease which you need to loosen. If not kindly check it up for something that is blocking the shift. Thanks for asking.
Jun 13, 2011 | DeWalt DCD770KL 18Volt Cordless 12Inch...
Porter cable hammer drill 987 suddenly stopped running.
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Mar 04, 2011 | Porter Cable 987 19.2 Volt Grip - To - Fit...
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
I have a three year old hitachi dv18dl cordless hammerdrill. The low gear is stripped and the trigger is intermittant. I tried taking it apart but saw nothing obvious. Any ideas on what to do or where to...
http://www.ereplacementparts.com/hitachi-dv18dl-18v-30ah-lithium-ion-cordless-hammer-drill-parts-c-7927_13467_13346.html
Here is the diagram for the drill. I would replace the gearbox and dc control switch. But it may be cheaper to buy a new drill.
Nov 25, 2009 | Hitachi Dv18dl 1/2 18v Cordless Hammer...
Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
May 24, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Hammer Drills differnces
Hammer Drills combine the rotation of a regular drill with a pounding action. These two actions enable the hammer drill to bore holes in masonry quickly without burning the bit.
Aug 27, 2008 | Dewalt DC2PAKCA Heavy Duty Xrp 18V...
Dewalt DC925 Cordless Drill Logo
206 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
