Question about Mitsubishi WD-73837 73 in. HDTV
My WD-73837 shut off on its own yesterday, I turned it back on and the welcome screen came up the the show I was watching but only for about 30 seconds then it shut off again, the status light was blinking red. I tried several more times and the same result. Contacted Mitsubishi they said that it may need the software updated, so per there instructions downloaded them to a flash drive then attempted to upload to the TV. It never stayed on long enough to show that it was uploading and now won't even show the blue welcome screen before it shuts back off.
3 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: mitsubishi wd-73837 doesn't turn on at all, no
I'm sure it's nothing you did wrong. I maybe a blown fuse inside causing the problem or a bad power supply. But, I wouldn't open up the TV. It may void the warranty by playing around inside.
Best to take it back and exchange it for another one. Tv repairs now and days cost an arm and a leg. Use warranty to full advantage.
Posted on Sep 01, 2009
jeramie_curt
  • 36 Answers
SOURCE: flashing green light and then blue welcome screen
Possible bad lamp, color wheel or both. Do you also hear a grinding or louder than normal whirling sound? If so, then it's your color wheel. If not, try just replacing the lamp.
Posted on Feb 02, 2012
Model WD 73837. plugged in head set and the speakers turned off. How do I turn them on?
It's an either/or choice. Normally, speakers are cut off when headphones are connected.
Jan 01, 2016 | Mitsubishi Televison & Video
WD 73837 HAS MENU PROBLEM.ALL MENUS WILL NOT FUNCTION WHEN ACCESSED.AFTER ACCESSED THE TV CAN ONLY BE SHUT OFF BY USING THE CONTROL PANEL.
Sounds like corrupted firmware. Contact any service technician. However, try a reset to this set, and check before doing a firmware update. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Nov 21, 2014 | Mitsubishi WD-73837 73 in. HDTV
What can be done to repair
This is usually due to physical damage from the screen being touched or bumped. There is no way to repair.
Aug 01, 2014 | Mitsubishi WD-73837 73 in. HDTV
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
I get sound but no picture then the tv shuts off after 5min. It is a Mitsubishi wd-73837
Popping noises are not a good sign; I suspect the sound came from the catastrophic death of an electrolytic capacitor or worse, the death a a power semiconductor.
Open the lower cabinet and using a good light, look for a smaller, separate board with fairly large parts on it; some cylindrical in shape, others block-like that may have copper wire showing.
If, as common, this board is plugged with connectors into other parts of the system, you may be able to swap the failed board out for a replacement bought from a Mitsubishi service center.Expect to pay $100-$150 US if the set is no longer under warranty.
Nov 23, 2011 | Mitsubishi WD-73837 73 in. HDTV
WD-73837 73 in. HDTV TV: hook up the coaxial cable from the tv to the recei...
7.1 surround sound will not work with a coax connection OR Composite (yellow video with Red and White audio). You either need to use an HDMI cable or the Component connection (Red, Green, and Blue connection along with the Red and White audio or the optical audio connection).
May 18, 2010 | Mitsubishi WD-73837 73 in. HDTV
Mitsubishi wd-73837 doesn't turn on at all, no status light or anything...brand new out of box
Sep 01, 2009 | Mitsubishi WD-73837 73 in. HDTV
Mitsubishi WD-73837 73 in. HDTV Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
