Question about Nikon S8100 Digital Camera
S8100 won't turn on after being dropped. - Nikon S8100 Digital Camera
  • 62 Answers
Sounds pretty straight forward. The impact most likely damaged the camera. Take it in to a service center to be checked out.
Posted on Mar 19, 2011
Nikon S8100 digital camera won't power on even with new battery.
1_ recharge the batteries or replace
2) clean the contacts batteries with contacts cleaner very well with carefully
3) see if the battery is loaded in WRON direction
4) memor card slot/battery cover is open.
5)poor contact between camera and battery terminal adjust the contacts and clean.
God bless you
Jul 31, 2012 | Nikon S8100 Digital Camera
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Jul 31, 2012 | Nikon Coolpix S8100 Gold Digital Camera...
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
Apr 24, 2012 | Nikon Coolpix S8100 Black Digital...
Canon S8100 battery won't charge
well somethings wrong with your canon S8100 battery or you need a new charger, or battery
Apr 24, 2012 | Nikon S8100 Digital Camera
Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Mar 22, 2012 | Nikon S8100 Digital Camera
Nikon s8100 not recognised by usb
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer and Picasa.
Feb 03, 2012 | Nikon S8100 Digital Camera
Nikon coolpix s8100 lens error lens won't retract
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 07, 2011 | Nikon S8100 Digital Camera
Nikon coolpix s8100 will not turn on. i have only used the camera a few times, and it was recently charged. is there a manual reset button? or do i need to send the camera back to nikon?
If it won't turn on, you're not going to be able to reset it.
Other than sending it back, the only suggestion I can make is do you have or can you borrow a spare battery. If so, try that. It could just be a failed battery.
Aug 26, 2011 | Nikon COOLPIX S8000 Digital Camera
Does the Nikon S8100 seem to have more lens error problems than other cameras?
Not really. It's extremely common on all similar designs from all manufacturers which have retracting/zooming lenses. The trick is to try and prevent the lens from ever being obstructed and to keep the camera in a camera case whenever it's not in use. Also avoid sand/beaches or similar areas as the camera isn't designed to cope with dirt which can get inside due to wind or being dropped.
None are robust, if they fail under warranty they get fixed or replaced. Outside of that you either fix it yourself or bin it and buy another as professional repairs usually cost more than buying another model.
Jun 20, 2011 | Nikon S8100 Digital Camera
My nikon s8100 won't turn on when I press the on button... but it will light up green when I plug it into the charger! help! :( I just got the camera!
It means it has a bad battery since it recognizes power using a different power source. Replace the battery and it should work fine.
May 10, 2011 | Nikon S8100 Digital Camera
Nikon S8100 Digital Camera Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
