Question about Panasonic Televison & Video
Where do I get a pedastol bracket? - Panasonic Televison & Video
    Problem Solver:
  • 9 Answers
How do fit a wall bracket on 50 in techwood tv
TECHWOOD 50inches TV Wall Mount Bracket TV BRACKETS TV WALL BRACKETS...
You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
Semper Fi,
Z
Jan 30, 2018 | Televison & Video
Tip
How to Identify the Type of Bottom Bracket on a Schwinn IC Pro
Video about Identifying the Bottom Bracket on a Schwinn IC Pro Bike
  • This video will help easily determine what kind of bottom bracket you need for your Schwinn IC Pro
  • You see in the video there are four available
    • The first one showed is the OEM style bottom bracket, on both ends it is a square tapered shaft bottom bracket
    • We offer a Sportsmith bottom bracket kit including the crank arms and crank bolts
      • This is also a square tapered shaft bottom bracket
    • We also offer two ISIS style bottom brackets
      • One is a 1 7/8" diameter
      • The other is 1 3/8" diameter
      • As you can see in the video these both have a round splined shaft
      • To identify which ISIS bottom bracket you need you will want to remove the crank arm and measure the hole in the frame that the bottom bracket mounts into
  • You will have to determine if you need a round splined shaft or a square tapered shaft
  • If you do need the round splined shaft you will have to know if you need the 1 3/8" or the 1 7/8" diameter bottom bracket
  • Knowing these things can reduce the frustration of buying the wrong parts and shorten down time greatly
How to Identify the Type of Bottom Bracket on Schwinn IC Pro
on Feb 25, 2015 | Schwinn Ic Pro Indoor Cycle
To remove the ignition coil on my 97 astro do i have to take off the whole bracket or is there a way to just get the coil off?
Hello: There are two screws one on each end. Remove those two screws, pull it up. The screw heads should be 5.5 mm or 7/32
Aug 25, 2011 | 1997 Chevrolet Astro
Ok i dropped the motor now its still a cross line i have to get past before the belt is install any suggestions
REMOVAL
  1. Remove the following components.
    1. The engine mounting bracket lower nut.
    2. The engine mounting bracket lower stud.
    3. The engine mounting bracket lower spacer.
  1. Remove the belt.
INSTALLATION
  1. Install the belt. Install the following components:
    • The engine mounting bracket lower nut.
    • The engine mounting bracket lower stud.
    • The engine mounting bracket lower spacer.
It really is that easy.
Jan 29, 2011 | 1997 Buick LeSabre
I need the exact location of the break light switch on a 92 labaron 2.5
The brake light switch is mounted to the brake pedal bracket assembly, under the instrument panel. The stop lamp switch attached to the mounting bracket.
  1. Disconnect the negative battery cable.
  2. Unplug the two brake switch wiring harness connectors.
  3. Remove the wiring harness for the switch from the clip on the brake pedal bracket assembly. Remove the nut and washer from the switch and bracket assembly stud and remove the switch and bracket assembly. To install:
  1. Position the switch and bracket assembly to the brake pedal bracket assembly, then install the nut and lockwasher. Tighten the retaining nut for the bracket until finger-tight (loose enough to allow movement of the bracket).
  2. Attach the electrical wiring harness connectors and route the wire through the retainer clip.
  3. Push the switch forward (toward the front of the vehicle) as far as it will go (this will cause the brake pedal to move forward slightly).
  4. Gently pull backward (toward the rear of the vehicle) on the brake pedal until the pedal lever rests against the its stop. This will ratchet the switch back to its properly adjusted position.
  5. Tighten the switch and bracket assembly mounting bracket nut securely.
See fig for more detail:-- helpmech_9.gif
-------------- This should help.Thanks.Helpmech.
Jan 12, 2011 | 1992 Chrysler Lebaron
How to install
The large bracket will go on top, with the taller part of the bracket facing the front. The small bracket will connect to the bottom of the unit. There should also be 2 brackets that go on the side with accordion style covers to cover the side of the unit.
Mar 23, 2010 | Danby DAC8003D Air Conditioner
Have installed a throttle body spacer for 1995 honda civic from OBX racing sports, almost done but my cable adjustment bracket has to be moved , so there is a bracket that came with the spacer and i dont...
Doesn't look like it goes in the same place as the old bracket?
No?
Then look along the intake manifold, and see if there are bolts that line up, with the holes in the bracket. Align the bracket inline with the cable, move the bracket forward, and backward to see about possible mounting holes.
You may have to flip the bracket around in several positions. A lot of times appearances can be deceiving. The bracket may fit in a completely different position than looks to be obvious.
http://www.obxracingsports.com/products.php?pk=1432
Aug 31, 2009 | 1995 Honda Civic
Scanner reads code (060)
Location of "ECM" is Under the Air Filter Box
  2. Remove the air cleaner box, refer to the air cleaner box.
  3. Remove the gray and black connector from the PCM.
    1. Remove the harness clip bracket from PCM bracket.
    2. Remove the nut from the upper bracket mount.
    3. Raise vehicle and support on hoist.
    4. Remove 2 lower bracket bolts.
      1. Remove 4 screws from bracket and remove bracket from PCM.
      INSTALLATION
      1. Install bracket to PCM and tighten screws.
      2. Install PCM and bracket to body and tighten the 2 lower bolts.
      3. Lower vehicle.
      4. Install upper bracket nut and tighten.
      5. Clip in wiring harness bracket.
      6. Install gray and black connectors to the PCM.
      7. Install the air cleaner box, refer to the air cleaner box.
      8. Connect the negative battery cable.
Mar 14, 2009 | 2001 Dodge Neon
Televison & Video Logo
13 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
