Question about Packeteer PacketShaper 2500 Network Monitoring Device
I want administrator or root user name and password for packet shaper 2500
  • 4 Answers
There is no root access, the OS is not *nix ish, there are 2 levels of access:-
look and touch, depending on the password entered takes you to the relevant level of access
Posted on Aug 01, 2011
Forgot administer password
Which password? Bios? Windows? Linux? Mac?
May 11, 2015 | Acer Aspire m5640 PC Desktop
How do i override admin password
Restart the PC, hold down F8 once you enter the Windows® Boot Menu choose
Safe Mode with Command Prompt, and now type in the following:
net user root /add
net localgroup Administrators root /add
net localgroup Users root /delete
The first command adds a new user called "root", the second command adds
that user to the Administrators group and the third command removes the
user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at mine Password Reset Disk Step-by-Step Guide.
Direct link: http://www.itknowledge24.com/
Nov 09, 2014 | Medion Computers & Internet
Change password
Change password for what ?
Use dos comand
The administrator account on a Windows machine is the main, root user name that gives full access to the machine.
Administrators should change this password frequently to avoid unauthorized access to the domain or desktop machine.
This can be done in the Windows Control Panel, or use the "net user" command in the Windows DOS prompt.
Log in to the machine using the administrator username and password.
You can also use an account that has administrator privileges on the domain or desktop computer.
Click the Windows "Start" button and select "Run" or "Start Search" (depending on your version of Windows).
In the text box displayed, enter "cmd" and press the "OK" button.
This opens the command prompt window.
Type "net user administrator <new password>" into the command prompt.
Replace "<new password>" with the password you want to set.
Enter the password again for confirmation.
Once you enter it again, the administrator password has been changed.
Test the new password by rebooting the machine and logging in with the new administrator password.
Dec 05, 2013 | Computers & Internet
Safe mode windows
if you didn't set the default administrator password, then you should
have been able to pass. However, if you remember that password, then please typed it in. Else you either need to download a third-party software that does the job, or you do the following instead.
Restart the PC, hold down F8 once you enter the Windows Boot Menu choose Safe Mode with Command Prompt, and now type in the following:
net user root /add
The first command adds a new user called "root", the second command adds that user to the Administrators group and the third command removes the user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at a Password Reset Disk Step-by-Step Guide.
Sep 27, 2013 | Dell Latitude D830 Notebook
HP Centario running Lenux I reset the CMOS battery and the blue screen still comes on says password required what am I doing wrong?
if you are running linux ubuntu
http://www.howtogeek.com/howto/linux/reset-your-forgotten-ubuntu-password-in-2-minutes-or-less/ Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop. Click "Terminal" to open a terminal window. Type the following command at the Linux prompt and press the "Enter" key: sudo passwd To change the Administrator account password, the password of "root" is changed. The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root." First, the user will see a Unix prompt asking for the current user's password. Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root." Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password. Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset or Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard. You will be presented with the boot menu. Select "Recovery Mode" from the boot menu. It is usually the the second boot option. Wait for computer to boot up. You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt." Type "ls /home" and press "Enter." Note: The command starts with a lower case L, not a capital i. You will be presented with a list of usernames of accounts installed on the computer. Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password. Enter a new password of your choosing. Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter." You will be asked to retype your password. Re-enter the same password and press "Enter." Your password is now reset. Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
Feb 24, 2013 | Computers & Internet
Ubuntu adm password reset
sudo passwd
or
hope this helps
Oct 02, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Machine wth ubuntu OS. when I go to internet you tube request some flash installation to see videos, but when install machine request e the password to continue, the machie was a gift from an uncle to my...
Hi
"Yes" for installing any flash or any type or program you might Administrator password.
As default Ubuntu has no password set for the root user. To gain root access you have to type in your own user password. This is the password you set for the first user while installing Ubuntu. To manually set a password for the root user, type in the following in the shell:
sudo passwd
After that you are asked to type in the new root password twice. Finally, your root user has its own password.
Now you enter the your password to install the flash or any other program.
Cheer
Jul 10, 2011 | Acer Aspire One D250 (99802378332) Netbook
I Have HP Compac c301 laptop I forgot my Password how to log in to my laptop
You can always log in as the root administrator by pressing ctrl+alt+del on after you've reached the logon screen. Key in the user name as "administrator" and the password. Hope the password is blank.
Once you are logged in as administrator, you can reset your account's password using the User Accounts in Control Panel.
Jul 14, 2010 | Computers & Internet
Forgot my password in my g3
Root user is special user in Mac OS X, has high privileges and rights to make any type of change to the system, and is different than administrator. If you forgot root password, see how to reset Root user password using different methods in Mac OS X.
How to Reset Root User Password on Mac OS X
May 11, 2010 | Apple PowerBook G3 Mac Notebook
Forgot password to log on to notebook
  1. i found this floating around, hope it helps, let me know please
Start up from a Mac OS X Install CD (one whose version is closest the the version of Mac OS X installed). You should first disable Open Firmware password protection, if it is enabled. Hold the C key as the computer starts.
  1. Choose Reset Password from the Installer menu (or Utilities menu in Mac OS X 10.4 Tiger). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
  2. Select your Mac OS X hard disk volume.
  3. Set the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually a reference to the root user. Do not confuse it with a normal administrator account.
Jan 29, 2008 | Apple MacBook PC Notebook
Packeteer PacketShaper 2500 Network Monitoring Device Logo
107 people viewed this question
Top Packeteer Computers & Internet Experts
David Payne
David Payne
Are you a Packeteer Computer and Internet Expert? Answer questions, earn points and help others
