Question about Refrigerators
I NEED THE PART NUMBER OF THE CONTROL ( THERMOSTAT) THANKS
  • Refrigerators Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
Food on top shelf is freezing
Not sure what model you have so I need to guess that it only has a thermostat control that regulates temperature? Can you post the Model Number? If your model only uses the temperature control to regulate temperatures then I suspect that the temperature control is at fault and needs replaced. Spare parts HERE Can you locate your model number? Click HERE I am here should you need me, Thanks John TrippAppliance 911
Contact Me Here
Mar 12, 2014 | Hotpoint-Ariston Refrigerators
Kenmore 106 56666500 not staying cold intermittantly?Does this sound like a defrost thermostat problem?
Look into the freezer and at the rear wall does it have frost building like the photo HERE If yes you will need to manually defrost the freezer with a hair drier or by placing a bucket of hot water inside the freezer and closing the door. Remove the rear wall of your freezer and see if the defrost heater and the defrost thermostat are good. This is the defrost heater part number=> 2323198 Defrost Heater Assembly The defrost thermostat part number is 2319914 Defrost Thermostat If both test OK the next part is found inside the fresh food compartment and behind the control panel=> 2313172 Main Control Board I am here to answer any questions you have, Thanks Sea Breeze
May 22, 2013 | Refrigerators
Motor is not turning on, I have to turn the knob back and forth
You will need to replace the thermostat in the unit.
Nov 18, 2011 | Refrigerators
My Honeywell thermostat is displaying everything and the touchpad will not work. What could be the problem? We need it to control our air conditioning but it also controls heat in the winter. Thanks!
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jun 10, 2010 | Honeywell Programmable Thermostat Heater
The unit freezes up then don't work
OK I'm looking over the manual and as long as the model number is correct RS2630SH you may have only one of three things causing this. I needing to go to another website to confirm the type defrost system yours has. I will send you a manual when I return. It appears that you have a higher possibility of a defrost heater or defrost thermostat defective.I am getting mixed answers on a decision of a defrost control board. Just make sure your model number does not have a different number or letter missing. I will send as much as I can find on your model but checking the defrost heater and defrost thermostat would be the first thing to do. Unplug refrigerator and remove contents of the freezer rear wall. we need to use a meter to check continuity through the defrost heater. If one is bad replace both defrost heater part number DA47-00154A and defrost thermostat part number DA47-10160F.
One model came with a defrost control board but I just cannot find one on that model number so the motherboard controls defrost. I will send manual shortly. Thanks, Sea Breeze
Jan 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
GSS201EMBWW Unit is freezijng up.
Most likely part number WR51X10101 Defrost Heater has burned out. Unplug and remove the rear panel inside the freezer. Defrost with a hair dryer and examine the defrost heater and look to see if burned out, It has a glass tube around the heater element and will be easy to see if burned out. If you need to replace the defrost heater you should also replace the defrost thermostat part number WR50X10054 If you don't see a problem with the defrost heater and I will instruct you on how to manually defrost to test the heater and defrost thermostat. Check for bad connections on wiring to heater and defrost thermostat. Your model has a mother control board part number WR55X10942 We may also need to check that because it does the thinking and determines the time for defrost. Let me Know what you find, Thanks, Sea Breeze
Oct 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My kennmore side by side,model number is59653462302
Your refrigerator has an Adaptive Defrost control board located inside the fresh food compartment and behind the control panel where you adjust temperature. This is the most likely reason for your troubles the part number is 12002495 The next most likely reason is the defrost heater part number 12049801 and the defrost thermostat part number is 67003377 But replacing the ADC is the main problem for your refrigerator and should be checked and replaced. Checking the defrost heater and defrost thermostat would be a good idea too, Thanks, Sea Breeze
Aug 28, 2009 | Kenmore 58162 / 58164 / 58169
Freezer is freezing OK. Refrigerator is not
I can tell you that if your model number PSS26MSRSS does not have a defrost timer. The most likely reason for freezing over of the evaporator coils will cause your fresh food section to appear warmer first are the defrost heater and thermostat. Defrost thermostat part number 332b542.jpg WR50X10068
WR51X10042 Defrost Heater
0872122.jpg or the Main Control board is defective. Part number
Click here to see or find these parts or email me at
appliancepartsoutheast@live.com
WR55X10656 Mother Control Board
I hva many solutions and welcome you to offer your Q&A to me, Thanks Sea Breeze
SITE 1=>
http://servicepartstec.blogspot.com/
SITE 2=> http://appliancepartsse.blogspot.com/
Mother Control Board is part number WR55X10656 We need to Check it for burn marks, on both sides. And this is what we need to look for.
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperture control switch not working
If the temp control works manually then that tells me that the tube that is connected to the thermostat is not telling the refrigerator compressor and fans to come on by sensing the temp change. The part number for the thermostat is 2198202 if the model number is correct above your post. If ED25PQXF is not the model number then we need to possibly change that number. Let me know, Thanks Sea Breeze
May 19, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Refrigerators Logo
500 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
