Question about Refrigerators
My KitchenAid side-by-side model is KSRG25FTSS (2008). It stopped cooling and the compressor is extremely hot to the touch. It hums but won't engage. Any suggesstions before I call a professional for service? Thank you.
  • Refrigerators Master
  • 2,605 Answers
Welcome to FixYa.
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized.
If you feel like you can trouble shoot further I`ve provided the following info to assist you or you may decide to call a professional appliance technician as I would suggest.
I don`t know the age of your fridge, but I should mention...
** Most of the manufacturers of fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay.
Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to the manufacturer and Sears for whom I am employed.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.My KitchenAid side-by-side model is - 775ec2d.jpg />775ec2d.jpg
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Posted on Mar 18, 2011
My refriderator stopped cooling properly.
Perhaps your cooling system lost the cooling fluid? (used to be freon)
Jun 16, 2014 | KitchenAid KSSC42QM Side by Side...
Compressor gets very hot
The compressor has a start device that could be the problem. If you remove it it should not rattle if it does it is very likely the problem. If it doesn't rattle then it could be your compressor. Check the start device first. it is located directly on the side of the compressor. and is easy to remove and install anoter.
Mar 04, 2014 | Bush Freezers
KitchenAid superba refrigerator freezer will not cool below 35° and refrigerator side hovers between 50° - 60°. Model KSSC42MHSOO.
either your cold control is bad or the compressor is bad or low on refrigerant, compressor will be very warm to hot to the touch if its low
Oct 26, 2009 | Refrigerators
Hi, the fridge side of my lg is not cooling enough. The freezer is fine. The black compressor in the back is extremely hot to the touch. What can I do?
If the evaporator fan stops that is next to the compressor that will cause this. The compressor being so hot does indicate that the compressor is under a load and possibly the fan or the start relay is causing the compressor to cut itself off too many times. I believe you have a sneaky condenser fan stop during its job and causes the compressor to overheat.
Sep 19, 2009 | LG LSC26905TT Side by Side Refrigerator
Door and rubbers are extremely hot and we are burrning ourselves while opening and taking food out
Your refrigerator has a stopped up Condenser Coil that needs cleaning with a vacuum cleaner. Also check that the Condenser Fan is working. The Condenser Fan may be bad....It sits under the bottom of the ref near the compressor and runs to cool the compressor. Hopes this helps! Handy Henry
Jul 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Divider between doors has extreme heat for side-by-side model
there are 2 pipes running there to reduce the temp in the compressor its normal
Jun 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
173 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
