Question about White Sewing Sewing Machines
My Mom's White machine is at least 45 years old and she hadn't used it for about 5 years. She started sewing with it the other day and broke a needle. When she replaced the needle, the machine 'wouldn't run'. I cleared the thread jam in the bobbin area and completely oiled the machine. It sounds fine when run without thread, but when threaded, the upper thread will not catch the bobbin thread. Help!
  • 12 more comments
  • Joan Mar 18, 2011
    Nope, the needle is inserted correctly - and we have tried another needle as well.
    When we turn the wheel by hand, we can see the upper thread come down outside the bobbin case completely to the bottom of the case but then it will not come around the case to pick up the bobbin thread - instead it comes back up on the right side of the case. The needle - and the thread itself (we changed that as well - is not the problem. Something is stopping the the thread from makiang it's complete circuit arou nd the bobbin case.
  • Joan Mar 18, 2011
    I did what you asked - it will not pick up the thread
  • Joan Mar 18, 2011
    No piece of the needle is in the bobbin case - the needle is a 'shorter one' - I have been sewing weekly for 35 years and my Mom was a seamtress for some 20 years. We know the common things to look for and can fix them. This is not a common problem with a common fix.
  • Joan Mar 18, 2011
    The upper thread will not catch the bobbin thread. It's not the needle or the thread or how it was threaded. In the many years that my Mom and
    I have been sewing we have never seen anything like this. The machine sounds fine if it's run at length without any thread. But once threaded, one of two things will happen: 1)the bobbin thread won't get caught at all, or 2) the upper thread gets so wound around the outside of the bobbin case that it jams the machine. The second thing happening is rare. Can you help?
  • Joan Mar 18, 2011
    I am not talking about bringing the bobbin thread up onto the work area. I am talking about the machine making the stitch itself. If you know how a sewing machine works, when the threaded needle descends, the thread it is carrying makes a loop completely around the outside of the bobbin case. When it comes around to the top again, it makes a loop around the bobbin thread (which is already on the work area). On my Mom's machine, when the threaded needle comes down to the bobbin, the thread is not making that complete loop around the outside of the bobbin case and therefore it is not picking up the bobbin thread. Can anyone out there help me?
  • Joan Mar 19, 2011
    Both my Mom and I have been threading a sewing machine correctly for years. This is not a threading problem. Will someone plese read my last comment on how a sewing machine works to make a stitch and see if they can tell my why the machine is not picking up the bobbin thread when the (correctly)threaded needle comes down to its low point in the cycle?
  • Joan Mar 19, 2011
    We have been thru everything you have commented on and none of these is the case EXCEPT a possible bobbin timing problem - it's not a tension problem, I KNOW what that is like and it's not that. How do I check for and rectify a bobbin timing problem. That's the one thing in your list that I know nothing about. Is that something I can correct? Or at least verify?
  • Joan Mar 19, 2011
    I did reply. I said that everything you have said, I have known about and tried. The only thing I don't know about is the bobbin timing. How can I verify that and fix it?
  • Joan Mar 19, 2011
    So how do I check to see if the timing is correct? Are there any internal marks to line up? I assume that the needle would have to be at either its highest point or its lowest point when checking the timing, but that's all I can think of. What else has to be looked at?
  • Joan Mar 19, 2011
    So how do I check the timing? I assume that the needle has to be at its highest or lowest point but there has to be something else to line up - maybe some marking to look at? Or the position of some mechanical item? Any clues you can give me?
  • Joan Mar 19, 2011
    I cannot get the picture you sent
  • Joan Mar 19, 2011
    Thank you - I hope it helps me - nothing and no one else has seemes to have had a clue!
  • Joan Mar 19, 2011
    This did not solve my problem but he was the only person who listened to what my problem was and he has led me in a direction which makes sense to me. Even tho the problem is not solved, he helped me tremendously.
  • Joan Mar 20, 2011
    Thank you for your help. It seems to be a bobbin timing problem. Thank you very much for reading my comments and not treating me like a novice on a machine - you are the only person to have done that. I am satisfied with, and grateful for, your help.
  • 2,510 Answers
(1) Check the needle or replace with a new one. A needle has a groove in one side of it and that is the side that the thread enters the needle. Some thread from the side and some from the front.
(2) Before sewing, manually turn the wheel to make the needle goes down while holding the needle thread with your left hand. When the bottom thread pulls up, pull both threads toward the back of the machine before sewing.
(3) Make sure that the needle si the correct needle for the machine and that it is not too short.
(4) Make sure your pressure foot has been lowered. Sounds silly, but if you lift is high it might just look like it is engaged.
(5) Try it on two ply fabric first and try both a straight stitch and a zig zag and see if you have problems with either.
(6) Make sure your thread is really machine thread and not hand sewing thread.
(7) Make sure the bobbin thread is feeding off the bobbin spool in the right direction.
(8) Anything other than these is probably a tension problem or a bobbin timing problem.
Posted on Mar 19, 2011
  • 2 more comments
  • Hans Pearson
    Hans Pearson Mar 19, 2011
    No response seen?
  • Hans Pearson
    This is a view of the position of the needle in relation to the bobbin hook if the timing is correct and the needle is set at the right height.
  • Hans Pearson
    There always seems to be a problem sending pictures in responses. I am doing something that we should not do and that is directing you elsewhere. Have a look at this site, it has pictures and instructions and hopefully we can solve you problem this way. http://www.fixsewingmachines.com/How-to-...
  • Hans Pearson
    Hans Pearson Mar 20, 2011
    As I said, I hope it helps, but if you have any problems at all, do not hesitate to come back to me at any time.
    Regards,
    HANS
    Genius:
  • 1,622 Answers
Hi, what makes the upper thread not to catch the bobbin thread is because you did not place it well in the bobbing area properly...
How to Upper Thread a Sewing Machine & Start Sewing
Threading a sewing machine appears complicated when you first begin sewing but all standard sewing machines thread in a similar manner. Sergers, sewing machines with multiple spools of thread on the machine, are threaded a bit differently. Sergers have an upper spool and a bobbin case that both need to be threaded. Once you learn to sew, you can save money by repairing, or tailoring clothing instead of buying them new.
Instructions
things you'll need:
Spool of thread
Find the end of the thread on the spool and unwind the thread two or three turns.
Place the spool of thread on the spindle at the top rear of the sewing machine. Most spindles stand upright but a few lay horizontally.
Find the thread guide at the back of the machine and run the thread through it. All threading should be in a simple line, never looped backward binding the thread.
Bring the thread to the front of the machine and run the thread through the top, farthest right guide, threading from right to left.
Bring the thread down the front of the machine and three quarters of the way around the tension adjustment knob from the right to the left. The thread will sweep up the tension wire and then be trapped on a guide beneath it. The thread should still be able to move easily through the tension guide.
Raise the thread pulling arm to the top by turning the wheel at the right end of the sewing machine. Thread the eye in the arm from right to left.
Bring the end of the thread down the front of the machine inserting it through any guides. On some machines the thread is slipped behind a hook rather having to thread it through the guide.
Slip the thread into the thread guide on the front of the needle holder.
Thread the needle from front to back. Pull a 6-inch tail through behind the needle.
Tips & Warnings
Do not use press on the foot pedal while threading the machine.
Posted on Mar 18, 2011
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Mar 19, 2011
    Hi, replace the bobbin case... That will do...
  • 10,865 Answers
Hello bjo... with an older machine, when you plunge the needle down into the bobbin case and come back up with a loop in the area, you have to take a spare needle, pin or whatever is handy at the time and pull that loop up....that is the bobbin thread.
Pull both threads to the back of the machine under the presser foot with the needle bar at its highest point and you are set to go.
This is one of those procedures you have to do everytime you insert a new bobbin or change a bobbin color.
It is also a good idea to get a scrap of fabric and then do a test sample to make sure everything is threaded correctly and ready to go for the project....saves you a big ripping hassle if it isn't and you are working on a project.
  • 4,924 Answers
This is happening cause you either did not inserted the needle in the correct position ..or is not the proper one ...If you do not have another needle ..try to let it out (to be longer ) a little ..mm by mm until it catches the thread ..
First look if you inserted it right ..and not the other way ..The flat part need to be on the arm side..and the screw will tide in the round part of the needle's thick part ..So ...oil it well and move it for 15 minutes ..and lower the needle until it catches the thread..probably the needle is a shorter model..
Also look inside for the tip of the needle not to be left in the bobbin area...
have a nice day ..
  • Catalin Turcu
    Catalin Turcu Mar 18, 2011
    Just try like I said to low down the needle half a mm ..and see if it picks up the thread or not..
Singer T&S 638, the whole bobbin assembly popped out. My mom-in-law said the needle caught and it just popped out. So it must be pssible to "pop" it back in, right? :)
Manual may be helpful:
Singer Touch Sew 638 Instructions Manual
Just an FYI, be sure to apply a couple drops of fresh good quality sewing machine oil as directed in the instruction manual. Do NOT use 3-in-1, WD-40, cooking oil, or old stinky brown sewing machine oil. Keeping it regularly maintained will keep your sewing machine running smoothly for many years.
Oct 20, 2016 | Singer Sewing Machines
What model would serial AF854490 and AL507447 I have 5 and 3 in cabinets from my 98 year old great aunt and her mom I was told. I have a 522 and an 1120.
Perhaps this web site would be helpful:
http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-sewing-machine-serial-number-database.html
Nov 18, 2015 | Sewing Machines
Do not know what size prewound bobbin i need to buy for a white 3300 embroidery machine
try this link, sewing parts on line says this is the bobbin for your machine, compatible with some Whites and Husquvarna Viking machines.
http://www.sewingpartsonline.com/bobbins-viking-white-10-pack-4120612-45.aspx
Genuine Part #412 06 12-45 or alternate code is 11770P
Jun 06, 2011 | White Sewing W3300 Computerized Sewing...
My mom has a White Model 1927, in which she use between 5 to 10 times when the machine broke. ( My mother has over 40 yrs experience in sewing. She use to make alot of my clothes when I was young.) When...
If, you turned the machine hand wheel away from you, you mess up the timing and I suspect that is the problem. If, I were you instead of investing another dime in the old machine, look into a new one from a place that gives lessons, I picked up a terrific one at JoAnn Fabrics, a Singer 7258 Stylist, for $199 and got a free lesson on it. It makes my $1000, Kenmore seem like an old truck and can do way more without having to adjust everything in sight . Good luck to you and your daughter.
Nov 15, 2010 | Sewing Machines
My zigzag broke on my Sewing Machine
Use white lithium grease on the gears, and sewing machine oil on the other ... or broken, get a replacement from your sewing machine supplier
Jun 26, 2009 | White Sewing 2037 Mechanical Sewing...
I'm looking for a price for a White #228 by Jaguar.
I purchased that same machine in 1993 for $800. The White Superlock 2000 ATS sergers were supposed to be the new deluxe model but it turns out that they didn't really work as well as they were intended to. In the years since then all of these sergers were being sold by liquidators. The current price is usually less than $200. for a new machine still in the box. Hope this info helps.
Jun 05, 2009 | White Sewing Superlock 2000 ATS Mechanical...
How to use white cams
hi! there,
white cam plate are mounted on top side of your machine there
is shaft for mounting on figure the plate cover opening for cam,then adjust the dial for the neccessary cam designed.32e83f9.jpg
you have to replace the presser foot on figures.5af54f1.jpg this presser foot is more convenient to use on designed cam
the stitch adjustment should # 8 to # 12 just select w/c more convenient to yuo,dial tension set to # 3 to # 6.
have a nice day,don't forget to rate me,thank's
Apr 26, 2009 | Kenmore Sewing Machines
Drive belt for old machine
You can get Necchi sewing machine belts here, all you have to do is measure your old belt and find that size
<a href="http://sewingpartsonline.com/sewing-machine-belts.aspx">Sewing Machine Belts</a>
Dec 15, 2008 | Necchi Sewing Machines
Sewing Machines Logo
136 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
