Question about Arrow Tools & Hardware - Others
My arrow HT55 hammer tacker is jammed and will not work
3 Suggested Answers
  • 2712 Answers
SOURCE: compare staple guns
A hammer tacker is a device somewhat similar to a staple gun, except that the mechanical energy from the user's muscles is stored — as in a hammer — as momentum of the gun itself, rather than as compression of an internal spring. This type of stapler is typically used for insulation, roofing and carpeting.
Posted on Aug 27, 2008
SOURCE: heavy duty- professional hammer tacker
how to load
Posted on Jun 18, 2011
My Stanley PHT150 is jammed and I cannot remove the staple channel. The instructions do not address a jammed staple channel so, how does one remove it?
Hi Dave,
Nice and easy this one.... all you've got to do is remove the chrome coloured pin at the handle end. This then allows the magazine to be removed by pulling it from the front end. Just make sure that you've removed the pusher (Where you feed the staples in) from the back first
Sep 18, 2014 | Stanley PHT150C] SharpShooter Heavy Duty...
I have a Stanley SharpShooter PHT150 that's jammed. I would like a diagram/instruction sheet showing how to fix this problem. Thanks.
Here is a copy of the instruction manual for your stapler.
1. Press end clip in, then up.
2. Pull out spring assembly.
3. Load staples into channel.
4. Reinsert spring assembly and
snap end clip into place.
EASILY DISASSEMBLED
FOR CLEANING:
1. Squeeze stapling end of hammer
tacker together, taking care to
avoid sharp staple.
2. Remove locking pin.
3. Press end clip in, then up.
4. Pull out spring assembly.
5. Remove staple channel.
6.Clear and reassemble
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2011 | Stanley Tools Hammer Staple/Tacker -...
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
A staple jammed in the moving part (driver?) when using to staple. How do I clear the jam?
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Feb 05, 2011 | Heavy Duty Arrow Ht30 Light Wire Hammer...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
REATTACH PARTS
Should slifde right together from the back. If you will go to the company web site, there is an exploded picture there for your convenience.
I hope this helps
a
Oct 02, 2009 | Arrow Fastener T27 Light Duty Household...
Compare staple guns
Aug 27, 2008 | Do it Best Imports/ Jaun Yei 326409 Cable...
Tools & Hardware - Others Logo
735 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
