Question about Fisher and Paykel GWL11 Top Load Washer
My GWL15 washer will not drain when wash cycle is finished, so will not rinse and proceed. Had a penny in drain hose also- still not working. Motor seems warm but cannot tell if it is coming on when goes to rinse. How do I know if it is the motor, pump, etc.?
    Brigadier General:
  • 6,277 Answers
(Try these guidance notes)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
My gwl 15 cannot get through the first rinse cycle. I hear the pump motor hum for about 16 seconds and then cut out for a second then continually repeat this cycle.The wash cycles completed ok and the...
Sorry about your Steelers.
I am currently pulling my washer apart again. This is the third time in about 5 years. Twice before I found pennies in the short black tube between the pump and the gray divert valve. I call it my 31 cent problem as the first time it was three dimes and a penny. I recommend turning the pump by hand. If it is turning freely, then I would squeeze the hose to see if you can feel anything inside. The tube is easy to remove and check as well, but any water is going to drain out on your floor. In my case I did not find any issue, put it all back together and it is running fine. Cross your fingers for me.
Feb 06, 2011 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
Washer won't drain and some cycles won't work
Make sure your drain hose is at least 2ft off the ground if your drain pipe is to low it wont drain
Feb 18, 2010 | Fisher Paykel EcoSmart GWL15
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Washer won't go past the wash cycle
YES !! check out the DRAIN MOTOR PUMP it could be clogged , AJ
Dec 18, 2009 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Problem draining &spinning
Get the strings coins and sand out the pump and retry
Dec 17, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
41 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
