My computer turns on, it shows POST i believe but does not load windows, is there a way to reinstall windows without the disc. I've tried going into safe mode and all that but it still doesn't load the screen goes blank...
  • 72 Answers
NO OTHER WAY BUT ONE THING U CAN DO U JUST BACK UP THE DATA USING BACK UP DISK.............AND THEN FORMAT THE SYSTEM
Posted on Mar 18, 2011
Computer not loading
Are you using Windows? This sounds like there is a problem with your boot sector and Windows is asking you to enter Safe Mode, Safe Mode with Networking, etc.
You can put in your Windows installation CD, if you have one, and repair the bootsector with the utility available on the disc.
If you save files to My Documents or anywhere else on the C: drive you could lose them if you have to reinstall Windows. You can reinstall Windows without deleting your files, WinXP only I believe. If you have to reinstall a factory image then that will overwrite everything on the target partition or drive.
Alternatively, you can use an external hard drive case to hook the hard drive up to then connect it to another computer. This will allow you to browse your hard drive contents and back up any important files that you have before reinstall your operating system.
Jul 06, 2012 | Computers & Internet
Windows XP Boot Up
USB Keyboard take a while to register. Try a serial type keyboard if your system has the Purple serial port on the back.
May 25, 2012 | Dell Inspiron 531s Notebook
My HP G60-630US notebook freezes during windows 7 loading up
Run the Check Disk Utility. You've got some bad or missing system or boot files.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 27, 2012 | HP G60630US Notebook
Computer turns on and after its done showing loading bar a blue screen appears . the computer then restarts with a black screen showing start windows normal, or startup repair. i chose startup repair
Try running the Check Disk Utiltiy.
Apr 25, 2012 | Computers & Internet
My compaq presario CQ61 crashed. Have tried recovery but everything has failed. I have got as far as installing window files but it now is asking for the installation disc - I have not got one
You tried recover and it failed, and now you are trying to reinstall windows but you don't have system disc. Hmmm, have you tried rebooting and going into safe mode. Just curious, but you've probably wiped out your operating system by now doing the two things that failed.
You're going to need an operating system disc to get you out of this.
Apr 01, 2012 | Compaq Presario Computers & Internet
Cant load roxio 2011 code error oood plaese tell me what to do its been 6hrs now cleaned everything please please
Please refer to the steps below and follow it carefully as it will help you resolving the problem.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall software
Jan 06, 2011 | Roxio Creator 2011
Whem i turn my computer on its says no operating system found.
Unfortunately that means either your windows installation is corrupt and needs to be reinstalled or the hard drive has failed and needs to be replaced. If you do not have a windows xp disc you will need a technician to do this as you will not be able to without the disc. If you do have a disc however follow these steps.
First insert the windows XP disc into the drive
Then when the machine says press any key to boot from CD press enter
Wait for the windows setup to load completely
Then highlight the windows XP partition it should be labeled windows XP
Then hit R on the keyboard
This will start a repair installation of windows
If it does not show the windows xp partition try installing to unpartitioned space
If the windows disc cannot find the hard drive or the repair does not completely unfortunately it means that the hard drive has failed and needs to be replaced.
Feb 26, 2010 | Compaq Presario 5000 PC Desktop
Program which has lost its path.
Hai,
It sounds like you are very much familier with computer and you do not what exactly needs to be done, no problem we are here to help you.
If the problem is not more than 14 days then, I suggest you restore the computer else.
Please uninstall the game or application that you are facing the problem with, if this could not fix the issue then I suggest you format the computer and reinstall the operating system, to reinstall the operating system I will provide you a weblink which has detailed information on installation of XP.
http://www.petri.co.il/install_windows_xp_pro.htm
similarly you can find vista and windows 7 installation guides, please make a note of the steps and perform the installation.
This should fix the issue.
Bye, take care
Feb 02, 2010 | Microsoft Windows Vista Ultimate Edition
My computer crashed and it won't boot up. i don't have a recovery disc, is there anyway to load it back up without taking it to someone?
You can press F8 during the POST to get the SAFE MODE option and try and go into safe mode and see if you can do a system restore while in safe mode.
Nov 06, 2009 | Toshiba Satellite A215-S4747 Notebook
Computers & Internet Logo
David Payne
David Payne
