Failure to boot. media test failure, operating system not found. how can I rectify this problem
    Brigadier General:
  • 10,406 Answers
Your computer tries to read from several devices, to try to load a copy of Windows:
* CD/DVD drive
* your disk-drive
* via your network-adapter, to communicate with a "boot-server" on the network
* 3.5-inch diskette
Your computer has tried each of the above devices, and found that NONE of them, including your disk-drive, contain an Operating System.
Either:
* your disk-drive is getting no power from your computer
* the "data" cable for the disk-drive is not connected to both the disk-drive and the motherboard
* the disk-drive is not spinning (dead motor)
* the electronics on the circuit-board under the "spinning" part of the disk-drive have failed.
Check the power/data cables. You may need to replace the disk-drive, and reinstall Windows.
Posted on Mar 18, 2011
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
When I turn it on, it makes a continuous sound for aprox 30 secs, then shows "PXE-E61 Media test failure". When working, it self-fills any empty fields with "n", not allowing any wrting...
Dec 04, 2010 | Toshiba Satellite L505-S5966 Notebook
Computer wont boot error msg says media test failure check cable operating system not found
problem in your boot device.check your HDD is properly connected and working properly.
if HDD is good,you must install your operating system again.
Hope this will helpful..
Nov 22, 2010 | Computers & Internet
Operating System not found
first checkout that your harddisk is detecting on startup or not.
May 08, 2010 | Acer Aspire One PC Notebook
PXE-E61 media test failure on Acer Aspire 5050 laptop
Yes, your analysis of the problem is correct. The problem could be with the hardware & while you are trying to reinstall the Windows OS, the software checks on all hardwares before installing. The best solution would be to take your system to a nearest service provider & get the problem rectified. Once the problem is rectified by them, try to reinstall the OS along with them, so that if there is any other problem apart from the above they will be able to help you.
Feb 08, 2010 | Acer Aspire 5050-3242 Notebook
PXEE61:media test failure, check cable PXEM0F:exiting PXE ROM operating system not found
You didn't ask a question. I assume this is an error on boot-up? If so, then the system is reporting that no pxe server was found to boot your system over the network. To correct this you should enter the BIOS setup upon power-up (via hitting the delete, f1, f2 or f10 key - depending upon your computer) and disable the boot from network setting. Save configuration and restart. You should probably set BIOS boot order to 1st device = cdrom, 2nd device = harddrive.
Jun 19, 2009 | Computers & Internet
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
Computers & Internet Logo
David Payne
David Payne
