Question about HP cp1700 Color Inkjet Printer
Hi,my printer is hp business inkjet 2800 ,now it's saying ATTENTION,CARTRIDGE STALL...clear carriage obstruction and press resume to continue....what i have to do?
  • 72 Answers
ONCE CHECK UP THE CATRIDGES OF UR PRINTER AS THEY MAY BE A PROBLEM IN IT .............
Posted on Mar 18, 2011
    Brigadier General:
  • 10,406 Answers
The print-head mechanism should slide from side-to-side, to print across the entire width of the piece of paper. But, this is not happening -- it is "stalled", or something is physically blocking its travel, or the mechanism that moves the print-head has failed.
Open the lid that covers the print-head mechanism.
Wait 20 seconds, and the print-head should slide across.
If it does not, then something "physical" is wrong.
Remove anything that is obstructing the movement. Press RESUME.
Or, take the printer to a qualified technician, for professional trouble-shooting.
Or, replace the printer.
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
"Carriage Stall....Clear Carriage Obstruction and Press OK to Continue" error nessage
If you continue with this issue then if your printer is under warranty say if it is within one year old then go to your vendor and tell them to replace the printer under warranty.
Sep 21, 2010 | HP Photosmart Pro B9180 InkJet Printer
Carriage stall.. clear carriage obstruction and press resume...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jul 27, 2010 | HP cp1700 Color Inkjet Printer
Hp business ink jet 2800 printer carriage stall clear carriage obstruction press resume to continue
i get this message on my printer
carriage stall clear carriage obstraction
i change the prints head and the colours catrage and still have the same message
can u help me
Jun 30, 2010 | Office Equipment & Supplies
Paper feed not working. green button and orange
I assume you mean that the power and resume lights are blinking. This signals a carriage stall. Open the top cover, if the cartridge cradle moves to the right, it isn't stuck and may be a one-time issue. If it is stuck, unplug the power to the printer. Open the access door and observe the carriage position. Clean any lint or paper pieces out. Remove any obstructions. Move the cradle and continue checking for lint, paper and obstructions until the entire area is cleaned out. If the print carriage started out on the left side, return it to that position to make sure the cartridges are back in the capping station. Look inside the printer along the cartridge cradle path for obstructions and remove any. Remove the rear access door and check for paper pieces, remove any obstructions.
Plug in and turn on the printer and see if the carriage returns to the left and reseats itself in the capping station. Close up the printer.
If this doesn't work, the printer may need service.
I hope this helps.
Mar 28, 2010 | HP DeskJet 5740 InkJet Photo Printer
Replaced ink cartridge but keeps saying replace
After you install a print cartridge, the attention light begins toflash red. The printer will not print. One of the following messagesmay appear on the control panel:
* Color or Right Print Cartridge is not compatible
* Incorrect Print Cartridge(s)
* Print Cartridge Problem
* Incorrectly Installed Cartridge(s)
* Black or Color Cartridge(s) Failed
Solution :
To solve the problems related to Cartridge Errors we can do thefollowing 4 steps. Which could help us to get the issue resolved
Step 1: Remove, inspect, and reset the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat repeating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step : Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE : you can also check the print cartridge label and make sure it iscompatible with your printer. Compatible print cartridges are listed inthe Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
Jan 04, 2010 | HP Business InkJet 2800 Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
HP Business Jet 2800 stall error message
See http://fixyourownprinter.com/forums/inkjet/42029
"Carriage Stall or Jam" by Stephen
Clean encoder strip with clean water, clean rod with denatured alchol you can get at Home Depot and lube with Synthetic Lubricant that you can purchase at a gun shop for about $4.
Mar 12, 2009 | HP Business InkJet 2800 Printer
DISK WON'T LOAD, TURN ON AND ALL THE LIGHTS CONSTANTLY BLINK
Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00095617).
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
  4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
Plug the product directly into a wall outlet Follow these steps to make sure that the product is correctly connected to a suitable power source.
  1. Make sure that the computer and the HP All-in-One both have a three-prong power plug.
  2. Remove the power cord from any power strips or surge suppressors, and plug it directly into a grounded wall outlet.
Perform a partial reset A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
  1. Unplug the power cord from the unit.
  2. Reconnect the power cord into the unit.
  3. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
  4. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
  5. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Remove and re-install the print cartridges Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
  1. With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center. The print cartridge carriage is the plastic part that holds the print cartridges. When the carriage is at the center of the access area, unplug the printer.
  2. Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
  3. Reinstall the print cartridges.
    • The black or photo cartridge goes on the right.
    • The tri-color cartridge goes on the left.
  4. Close the cartridge access door, plug the printer back in and turn it on.
Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP cp1700 Color Inkjet Printer Logo
613 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
