Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint cdt40 after setting the dryer press start button and it makes 3 beep noises and wont come on
  • Anonymous Mar 26, 2014
    hotpoint ctd80 when i press start it just beeps and wont turn on
    Genius:
  • 2,920 Answers
Your timer maybe out
Posted on Aug 20, 2008
Red light flashing
Some of them TDs has a float which triggers a kill switch to stop the dryer if the water level exceeds the level and would overflow. Perhaps your float is stuck. I have not had the priv of working on one of these yet as they are not in my area. But I have been studying em.
Sep 24, 2013 | Hotpoint Dryers
My CDT40 is not heating when used and when I press the option lights, they flash once then go off
Check the bias thermostat on the blower wheel housing, thermal fuse, high limit thermostat, and heating element on the back of the machine for continuity with a multimeter. Replace any of the mentioned parts with new one form the parts list below. Below is a video to show you how to check for continuity. The dryer is a little different, but the principles are the same.
Bias Thermostat Thermal Fuse High Limit Thermostat Heating Element
Dec 30, 2010 | Hotpoint NBXR463EBWW Electric Dryer
The start button is flashing red and beeping and the drying cycle won't start. Help!
  • If the machine shakes or makes a lot of noise, make sure the dryer is level. Some shaking is normal, but it shouldn't bounce around like it's itching to go somewhere. Adjust the leveling legs. They just screw and unscrew. Check to make sure the load inside the dryer is properly distributed and is not all clumped together.
  • Match the control settings to the type of load, and make sure you're not overloading the dryer.
  • Check that the ducts aren't blocked if the clothes take too long to dry. Look for lint or missing socks. Check to make sure the ducting isn't kinked, and make sure the outside dryer vent flap moves freely and isn't blocked---by snow, for example.
  • Sort your clothes by weight if they aren't drying properly. Lightweight clothes should be dried separately from items like comforters.
  • Make sure the lint drawer is empty.
  • Press the "Stop" button or press the "Lock" button for three seconds if the controls don't work. Press the "Power" button to wake the dryer up if it won't start. Make sure the "Delay Start" button isn't flashing if the machine fails to start. Press "Start" again.
  • If you see only lights displayed on the screen and no numbers, it's normal. The dryer has detected a low level of moisture. Other normal behavior is when the time remaining jumps to a lower number---it's revising its estimated time remaining. When you can't make a selection and the dryer beeps twice, the dryness setting is incompatible with the chosen dry cycle hope this helps please tell me if it does
Dec 06, 2010 | Zanussi Dryers
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
How do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
Apr 07, 2010 | Hotpoint Ultima WD72 Front Load...
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Hotpoint Aquarius CDT40 wont turn on
CDT40 IS NOT A MODEL NUMBER
Apr 09, 2009 | Dryers
Hotpoint Aquarius WMA42 Front Load Washer Logo
140 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
