Question about Insignia NS-R2000
Can't run tv sound from my Vizio M190VA tv through my Insignia NS-R2000 receiver so it will play through my speakers in the ceiling which are connected to the receiver. Is it possible to do what I am attempting to do?
  • 961 Answers
You should be able to if there is an audio out on your tv that is compatible with your reciever. RCA, HDMI,or, digital optical. I looked briefly at your tv and it looks like there may be a digital optical out. It's hard to tell.
Posted on Mar 18, 2011
    Brigadier General:
  • 8,546 Answers
I have no idea why manuafacturers or users think a TV is a good place to originate sound in this Cable Box age. The Cable/SAT box is for all intents and purpose a hi-fi multichannel audio source like any other audio component, where the TV's audio was probably an afterthought.
With that in mind, source the TV-related audio directly to the NS and skip all that zig-zagging of audio all over the room before it gets to your ears.
I also recommend taking all high-end video directly to the TV/monitor from whatever sources you have. Added cabling (and cost) doesn't help. Let the specialty devices each handle what they master.
Does that help?
Where can I get a remote control.
I believe that you want the INSIGNIA KOR3551. You can find the remote using the following website.
http://ezremotefinder.com/results.php?mfg=INSIGNIA&mdl=KOR3551&keywords=&page=1
Jan 29, 2016 | Insignia Ns-r2000 200w 2ch Stereo Receiver
No sound from my speakers
Make sure your source is properly assigned and switched to respected input. Your speakers should also be engaged.
Mar 11, 2014 | Insignia Ns-r2000 200w 2ch Stereo Receiver
Can i turn my vizio m190va tv into a computer monitor?
Unfortunately. the HDMI port on the M190VA does not interpret the signal from a computer. The HDMI signal from a set-top box is different than that of a computer. You need to use the VGA port and the PC audio in on the TV; if your computer doesn't have a VGA port, use a DVI to VGA adapter or other appropriate adapter. You will need a 3.5 mm audio patch cable to use the TV's speakers. See page 25 of the M190VA manual here: http://store.vizio.com/documents/downloads/hdtv/M190VA/364User%20Manual.pdf .
I wish that I had better news for you.
May 08, 2012 | Vizio M190VA 19 Class Edge Lit Razor LED...
How do you hook up an mp3 player to insignia ns-r2000
You will need an Dual RCA to 3.5mm stereo cable. One similar to this: http://www.dcables.net/Dual-RCA-to-3_5-mm-Stereo-Cable-5-Feet.aspx
It would probably be easier to pick one up at your local Wal-Mart or Radio Shack.
Just connect the RCA connectors to one of the audio line inputs and the 3.5mm to your mp3 player. Set your insignia to receive the source you just connected.
Hope this helps
Apr 07, 2011 | Insignia NS-R2000
How do i get sound to work after plugging in a vizio speaker
you would have to go to the audio menu and switch it from stereo/mono to surround sound.Hope This Helps HAPPY HOLIDAYS!!!!!!!!!!!!
Dec 24, 2010 | Insignia NS-27RTV 27" TV
I have Suddenlink cable and an Insignia NS-R2000 receiver that I need remote codes for, please. Thank you, G
I went to Suddenlink website and they had the code that I needed for Insignia receiver.
Thank you
Nov 09, 2009 | Insignia Audio Players & Recorders
Insignia NS-LCD37 TV - no sound
Start checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Insignia NS-LCD37 37 in. LCD TV
I have a fm-am receiver #ns-R2000, I push the power button & it shuts down immediatly, What could be the salution?
The receiver is going into a protection mode. This happens because there is a failure either inside the unit itself or in something attached to it (such as the speakers).
A quick and easy thing to try is to disconnect all of the speaker wires. If your NS-R2000 now stays on, carefully examine all of the speaker wiring to be sure it is not shorted. Also check the speakers to be sure they work properly.
Oct 20, 2008 | Insignia Audio Players & Recorders
Check the impedance ratings of your speakers. Sherwood, the actual manufacturer of the NS-R2000 receiver, suggests that you use speakers with an eight ohm impedance if you have only one pair attached. If you have two pairs of speakers attached, the impedance rating of each pair should be sixteen ohms.
This is because Sherwood wired the receiver such that an additional pair of speakers is placed in a parallel circuit to the first set. When this is done, the impedance (resistance) of the load seen by the amplifier drops. As resistance drops, you get closer to a short circuit (no appreciable resistance).
Many other receivers wire the speakers in series, which causes the impedance to go up.
Personal experience seems to suggest that the amplifier is OK with a four ohm load on it. It does run warmer with a four ohm load, which is what you'd expect. It's when you have multiple sets of four ohm rated speakers that you will get into trouble, as this means the receiver only sees a two ohm load. This will cause overheating and shutdown.
At this point the power transistors in the amplifier may have been damaged. It may require repair. Fortunately, replacement parts are readily available (though not from Sherwood or Insignia). If it continues to shut down, stop using it. You could end up burning out your speakers.
Jan 09, 2008 | Yamaha RX-V2400 Receiver
Insignia NS-R2000 Logo
158 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
