When trying to Scan to Email from Konica Minolta C451 printer, they get an error message on the Control Panel Display stating "From Address not set, unable to Transmit, please specify From Address". I have created a New Account on AD and Exchange and then added this Email Address to the Fiery Web Portal, but still getting the same error. Any ideas?
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Posted on Jul 17, 2008
  • 6 Answers
SOURCE: Konica Minolta 250 Bizhub scanning Operations
what u need to scan to emails is the email smtp ip address.
just put the ip smtp address in the network setting>smtp address
and try to ping from ur B250, if the result is OK, then u have the connection. go to Utility/Counter>user setting>one touch to register
the user address, then scan it, u should be getting the scanned file in ur inbox.
Posted on Aug 09, 2008
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
I cannot scan to my email from my c451 now that I have a new website
check the mail server and check that a static ip address was isssued to the copier, copiers love static ip address.
Apr 24, 2014 | Konica Minolta bizhub C351 All-In-One...
When trying to scan to email from Konica Minolta C203 we get an error message "From Address not set, unable to Transmit, please specify From Address" any ideas.
need to create a from address in the copier either bye at the op panel or thur pagescope look up a you tube video how to set up to scan to email with a bizhub c203 or any bizhub 3 series
Nov 21, 2013 | Konica Minolta Bizhub c203 Copier
Error code c-6751 on konica minolta c451
C-6751 CCD clamp gain adjustement error.To reset turn OFF the copier.Press and keep pressed the Utility key and turn ON the copioer and wait for the Trouble reset message appaire on the display.Realease the Utility key and touch the trouble reset then turn OFF the copier.Wait 1 minutes and turn ON.
Mar 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C451 error C-3924
c7ff0589-2c1c-428b-8214-5be985c427d0.jpgkonica minolta c451 printing problem
Jul 16, 2012 | Konica Minolta Bizhub C451...
Base e-mail on a Minolta copier C451
ok the best way to do that is through the WEB interface. use a computer that is pluged into the same network the copier is. then login as admin PW is 00000000 or 12345678 then click on the scan tab. then change the email that your looking for
Nov 18, 2011 | Konica Minolta KONICA BR BIZHUB C451...
CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
May 14, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Mar 06, 2009 | Konica Minolta Office Equipment & Supplies
Konica minolta c252 how to sharing pc....
If you are just adding your PC to the network first go to control panel click network set-up wizard.
to add your PC to print add printer from the control panel and look for the network printer. last you want to scan go the internet web browser input the ip address of the scanner or copier click public or administrator enter password 12345678 and click scan tab and add your PC host name or your email address if scan to email.
HH
Jan 10, 2009 | Konica Minolta bizhub C250 All-In-One...
2,946 people viewed this question
k24674
jasbo
jasbo
