I have a savin 2518 copier It's printing very light do you have any idears
  • 604 Answers
First take the toner cart out and shake it, if that doesn't cure the problem, you may need to replace the toner cartridge with a new one
Posted on Mar 18, 2011
I replaced the tone cartridge in my Savin 2400WD copier, but the light still indicates that I need to change the toner cartridge. What do I do?
I hate to say it but switching it off at the wall waiting a minute and then back on sometimes resets its little brain.
I trust the toner cartridge is all correct for this model.
May 13, 2015 | Savin Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
How do you get rid of lines that are coming through on copies Savin 2518
U PROBABLY NEED A NE DRUM. OR HAVE DFIRT ON LENSES AND MIRRORS
Sep 13, 2010 | Savin Office Equipment & Supplies
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
Printing very light
it is possible the td sensor was left disconnected.If that is the case the dev will be shot to pieces by now. £££
Apr 19, 2010 | Savin 2575 Black and White Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Savin 8045e copier
That depends on what you are printing.
Any time you read stats about page count, it is usually based on 30% coverage of the page.
Depending on what you are printing, it can be more or less.
Estimated yield is 30,000 pages for a standard cartridge.
Using an aftermarket (refill) cartridge can vary greatly.
And as mentioned, it really depends on what you are printing.
Aug 05, 2008 | Office Equipment & Supplies
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
