Question about Sony Grand WEGA KFE50A10 50" SDTV LCD Projection TV
Dear sir, The diagnosis by you on the problem is correct. Confirm by sony that we have an optical block and bulb problems. Need to replace both. Where can I get a replacement parts for optical and bulbs. What will be the cost of the item individually. Delivery lead time. Thanks Michael
  • 10,594 Answers
Please confirm tv model number as question shows it is Sony KF-E50A10
Model number info is very important to provide you correct and helpful info.
Thanks.
Posted on Mar 18, 2011
I have a 2006 Sony KDF-55-E2000, just replaced the lamp and housing and now I have a green stripe at the top and a red stripe at the bottom. Is it worth having this set repaired if I do not have an ex
We had the same problem. Let it be and now the tv won't turn on. If I understand correctly from what I've read it's the optical block and they seem to be just as much as a new tv.
Jun 23, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a tv lg ru-60sz30 with yellow spots on the image. I guess it's the optical block
yes the yellow spots mean its a optical block problem. in your case it is the yellow LCD panel inside the optical block. this is not a diy fix you need special tools to realign the panel. sorry for the bad news.
Apr 05, 2011 | LG RU-60SZ30 60" Rear Projection...
I have a permanent blue light encroaching the picture on the lower left corner of our sony kdf-60xs955 60". Replaced the bulb recently.
The Optical Block is probably the cause of the problem. I am not sure if it is still a Recall issue but due to the cost of the repair, I recommend you call Sony at 1800-222-SONY and see if they can assist
in the cost of repairs and also to help locate a Service Facility to confirm the symptom.
I hope this helps,
Skyassoc
Oct 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Bottom right side of screen (about 4 inches high) has blue tint
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the "Optic Block", ($1300. -not incl labor), that was replaced to fix the problem. That part contains all new LCDs, & multiple Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended).
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have automatic FACTORY extended warranties (up to 10 years), because of some known problems with the blue LCD panels. You might want to contact a SONY office & see if your set is covered.
ALSO - The tech checked my Service Codes & showed me the TV had been running for 10051 hours in about 4 years - on the Original bulb! He was quite surprised because he said the bulbs usually last about 5000 - 7000 hours. He also said it's good to replace them BEFORE they go bad, because they can sometimes burn out the amplifier that powers the bulb, (which is a seperate piece that attaches to the outside of the Optic Block). My TV is like new now.
Dec 25, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
OUr Sony Grand Wega KDF-60XS955 has a blue corner
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the $1300. (not incl labor), Optic Block that was replaced to fix the problem. That part contains all new LCDs, & Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended)
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have FACTORY extended warranties because of some known problems with the blue LCD panels.
Dec 23, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue line problem with Sony Grand WEGA KDF-55WF655 Rear Projection TV.
We had the free repair from SONY for the blue dots and splotches. It works great now but you need to hurry and contact them as the offer expires I believe in December.
Sep 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Picture is getting Yellow screen on botton right corner.
Sony extended Optical Block until 06/302010. Will re-imburse your if you replaced the optical block out of your own pocket
from http://esupport.sony.com/US/perl/news-item.pl?news_id=277
Certain 2006 Model Year SXRD Television Extended Warranty Information – Optical Block
Posted: 10/21/2008
Models: KDS-50A2000, KDS-55A2000, KDS-60A2000, KDS-R60XBR2, KDS-R70XBR2
Aspart of the Sony commitment to quality, Sony is announcing that it isextending the limited warranty (parts and labor), in the United States,on the optical block of the above-referenced 2006 model SXRDtelevisions until June 30, 2010, regardless of purchase date. For anycustomer who requires repair of the optical block on one of theaffected models, Sony will cover the cost of the optical block repair(parts and labor) at no charge through June 30, 2010. This extendedwarranty does not apply to the replaceable projection lamp or the otherparts that may be used in the televisions.
Sony is also announcing that for any owner of these modeltelevisions who paid out-of-pocket expenses on or before November 30,2008 for an estimate or repair service to replace the optical block,Sony will reimburse the customer by mail for the cost of the opticalblock and the labor expense to replace it, subject to certainconditions. To receive reimbursement, please follow completely thedirections on the claim form for reimbursement; all claims must be postmarked by January 31, 2009. See the claim form for complete terms and conditions.
All other terms of the Sony limited warranty continue to apply. Sonyutilizes a network of hundreds of qualified independent third-partyservicers to perform in-home television warranty service. Sony, throughits authorized servicer network, will endeavor to repair your setwithin 30 days of your first contact. For diagnosis, warranty service,or if you are not provided a repair within 30 days, please contact Sonyat (888) 649-7669.
Aug 11, 2008 | Sony KDS-60A2000 60" HDTV
Yellow tint
I had the same problem (although I have the 50 inch version of the TV). It wasn't the bulb. The optical block had to be replaced.
Jul 12, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kdf 50we655
heat and dust are two major problems with this type of set.These set can get very dusty inside the optics and cause this type of discoloration .Heat can cause deteriation on optics and or optics cabinet parts .It is possible to clean the optics block for dust issues only but unless you know what your doing and know what areas not to touch inside optics block .Otherwise the block would have to be replaced..
Nov 12, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KFE50A10 50" SDTV LCD Projection TV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
