Question about General Electric Ge Security Keysafe Original 2-key Slimline Keybox
We just installed a KeySafe Original 1058358A on our building. I was given the instructions on how to set the combination, but before I could set one up, someone else was playing with it and now does not know what combination he put in. We cannot open this at all now. Is there any troublehsooting guides on how to open if you forget your combination. He doesn't even know how many numbers he used.
I just purchased it but it is close, what is the default safe code to open it? Thanks
RUSH BACK TO THE STORE WHERE YOU BOUGHT IT. The only one who can give you safe code is the one who sold it to you.
As if it has a default code? Electronic cosdes might be reset but of sourse, you should know the original.
https://www.youtube.com/watch?v=_tqTp57YfCw
http://www.safeoptions.co.uk/blog/how-to-change-number-on-keysafe-lock/
In any case, if someone with experience with a safe similar to yours might be interested to share his experience, you should provide make and model of you unspecified safe.
I've been lookin for safe mnauls on internet and got this one:
http://www.sargentandgreenleaf.com/pdf/630-302_6120_op.pdf
and also this one:
http://hilkab2b.co.uk/manuals/s-25ea%28ii%29.pdf
How To Change Number On Keysafe Lock Safe Options
Guses might find some better information should you provide make and model of your safe.
Aug 22, 2015 | Home Security
Change code combination
Setting the Combination
1. Remove the key holder from the KeySafe by pressing the RESET button, followed by the OPEN button. Pull down on the key holder from the bottom of the KeySafe
2. Remove the bracket. Press the Release tab on the bracket and slide the KeySafe upward until it is free of the bracket.
3. Remove the plastic card attached to the bracket. You will see ten numbered buttons with arrows. These numbers correspond to the numbered buttons on the front of the KeySafe. An up arrow indicates that the button is not selected, a down arrow indicates that the button
is selected as part of the combination.
4. Using the screwdriver tip on the plastic card, apply light pressure
to rotate the arrows on the buttons you've selected for your combination a half-turn to the downward position until it snaps into place. Caution: The arrows must either point up or down, with downward arrows representing the numbers in your combination. If any arrow is pointing left, right, or is not fully seated when turned downward, the combination will not work. Improperly setting the combination is not covered under the warranty.
5. Return the plastic card to the bracket for future use
Mar 10, 2014 | GE AccessPoint Digital KeySafe 001847
I dont know the combination for a supra keysafe that is on a door of a property I have just purchased
Well, you MIGHT be stuck and out of luck, however there are some tricks you can try. Check out the blog on http://suprakey.org/ - they have several solutions for those that need to reset the combination of a Supra Key lockbox!
Good Luck!
May 23, 2012 | Supra 001004 Push Button Lock Box Key Safe
LOST CODE ON SUPRA C LOCKBOX
I have just moved into a house that has a supra combination code key safe mounted on a wall outside the back door , it was put there by the first owner who died ,the second owner never used it and don't know the code,I just thought it would be handy to use as we are going away in June to France and its away of leaving a key in case the alarm goes off while away so a neighbour could deactivate it or the police so they don't have to brake down the door or if I get locked out I could have that key for emergencies so is there a way I could find the code for the safe please?
Aug 31, 2011 | Supra 001004 Push Button Lock Box Key Safe
How does one get a user's manual for this lock? It works wonderfully, but I need to change the combination and learn how to set the guest combination. Thanks in advance.
Installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
If it still doesn't work, contact Kwikset Customer Service:
customer service http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Nov 16, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Respected Sir, Somebody Has changed printer's original setting but I am facing problem to restore printer's default print setting. There was a sticker on printer's top on that some key combination was...
put a paper in printer
power off
press and hold menu bottn.
power on
a page will print
now change setting whatever you want by pressing LF bottn.and after that press save
power off printer and power on again your printer setting will be cganged as per your requirement
Oct 05, 2010 | Epson Dot Matrix LQ-300+ Printer
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Reboot to original settings
start in safe mode, then restart it normally
Feb 27, 2009 | Gateway Profile 4M PC Desktop
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Jan 14, 2009 | Toshiba MD13N3 13 in. TV/DVD Combo
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
General Electric Ge Security Keysafe Original 2-key Slimline Keybox Logo
355 people viewed this question
Top General Electric Home Security Experts
Lawrence Oravetz
Are you a General Electric Home Security Expert? Answer questions, earn points and help others
