Question about Zebra QL 420 Plus Thermal Label Printer
How to set a zebra ql420 plus to 'factory defaults'
SOURCE: Zebra 170 III Plus
there is an option in the advanced menu to restore to factory defaults, you will need to get the password for the level 4 menu from the manual
Posted on Nov 09, 2007
SOURCE: want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
Posted on May 05, 2009
printertech1
  • 96 Answers
SOURCE: Have a Zebra Z6M label
Your printer driver will overide the printer settings. Set the printer settings and save them. Then print config by hold the cancel while power on. Verify the settings are saved and correct. Then send a label to the printer and see if the parameters have changed. If they changed then change the printer driver settings to your preferences and try again.
Posted on Oct 14, 2010
ozztech
  • 285 Answers
SOURCE: How can I reset a Zebra LP 2844 printer to factory
press the green buton untill flash 4 times, then press untill flash 7 times to calibrate and print sensor profile. turn off and turn on again.
Posted on Nov 13, 2010
ozztech
  • 285 Answers
SOURCE: Zebra QL 220 Printer Reset
download segull driver (wwwseagullscientific.com) install, go to the setings, there is the Reset to Factory Defult.
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
How to enable ZPL on a QL420 wifi printer
Include this command before the start of your ZPL code:
! U1 setvar "device.languages" "ZPL"
Apr 20, 2011 | Zebra QL420 Thermal Printer
LABELS FOR ZM400
The labels for the ZM400 and the QL420 are not interchangeable.
Aug 10, 2010 | Zebra QL 420 Plus Thermal Label Printer
Zebra QL420 portable printer label gets misaligned frequently
There are two things to consider here: 1) Is the printer set to the correct media handling setting? Look in the manual for the terms BAR-SENSE and GAP-SENSE and make sure that you have sent the correct command to the printer. 2) There is a TOF or Top of Form setting that you can send to the printer to align the perforation of the labels with the tear bar. Look for the syntax in the manual, which is free for download at zebra.com, and make sure that your perfs line up with your tear bar.
Oct 19, 2009 | Zebra QL420 Thermal Printer
Want to reset my Zebra 140XiIII back to factory settings?
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra 170 III Plus
Apr 12, 2007 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra QL 420 Plus Thermal Label Printer Logo
782 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
