Question about Kenmore 44102 Front Load Washer
Getting the cover off of the kenmore elite front load washer
I don't know how to remove the front pannel of the washer to check if anything is trapped in there. It won't take a normal screw driver is there a special tool needed?
  • lisadrace Aug 05, 2008
    Thanks!!! With my bad eyes I couldn't tell that it needed that kind of screwdriver!! My washer is now fixed!!!! Thanks again.
  • 770 Answers
Torx screw driver i belive it is a #10 you can buy at any hardware store
Posted on Aug 02, 2008
Washer displays "suds" and then "f 35" and will not operate? what is this code and how can it be repaired?
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trap cleanout is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and F35 always appear
Just tilt the washer back and prop it up with some wood blocks. 3 screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trap cleanout is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Apr 02, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
LOCATION OF LINT TRAP?
Remove 3 screws from the bottom front panel and drop it down. The pump will be in front of you on the bottom.
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Getting an F 02 error code with my Kenmore Elite HE 3T
Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Where is the button trap located on a kenmore front loading washer
behind the lower panel, theres 3 screws across the bottom of machine remove them and youll gain acess to the button trap
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
How do you open the front cover for Kenmore front loader 110.42926200
Sure thing, under the door is a kick panel, held on by three hex screws,standard uses 1/4 inch and torx uses a 9/32 socket. A slight down tug will loosen the panel and behind that you will see the pump at right front. Just to the left is a round soda can shaped housing with a large turn screw lid attached to the pump. Grab a bucket and some towels, unscrew the lid like a jar of peanut butter slowly to let the water into the bucket. This may require two trips and some getting wert. The trap is attached and easy to clean. Next reach behind a gently shake the black boot joining the tub to the pump for coins and lint. The last item is getting a bright light and inspecting the pump through the small hole right side that can be seen once the trap is removed. Check for debris then put a finger in the hole and check the impeller for disconnection from debris/
Sep 08, 2008 | Kenmore Elite 45986 Front Load Washer
Front Load Washer
Jun 06, 2008 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
70 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
