I have a wireless router p/n cir655ana...a4 s/n f37x494004298 wps pin 19099125 http//192.165.0.1 username "admin" password= (leave feld blank) I need to know how to get the password and setup this router on an epson wireless printer and they tell me i need to contact you and get instructions. please respond Jeff ((403) 532-9289
oldnovii
  • 667 Answers
SOURCE: D-Link AirPlus Xtreme G DI-624 Router setup
Hi Alex - Don't rate this yet please. Are you just setting up this router for the first time? If it is, try resetting it. Put the end of a paper clip in the hole marked reset on the back . Leave the router plugged in. The lights will go off and on as the router resets itself. Try this and let me know what happens. Thanks.
Jeff
Posted on May 22, 2008
SOURCE: Dynex DX-E401 Router setup
username - admin
password - admin
Posted on Jul 10, 2008
SOURCE: Brother MFC-7840w wireless printer won't connect to network
For me, the quick solution was to use the 'Open System' instead of 'Shared Key', 'WPA/WPA2-PSK' or 'LEAP' authentication options on your printer.
However, after that, I decided to change the security settings on my router a bit. Log into your router, click the 'Home Network' icon at the top, and then check out 'Wireless Settings.'
The 'Wireless Security' section should tell you how your 2Wire is configured (which I eventually changed to WPA2-PSK.)
-DJ
Posted on Nov 15, 2008
  • 8 Answers
SOURCE: Epson px700w wireless
If you have wpa2 then it will not connect. I had the same problem. When i changed my router settings to wpa (you can chosse wep as well) the setup continued succesfully. You can also set the printer from its own menu without a pc.
Posted on Mar 21, 2009
  • 30 Answers
SOURCE: Can't login to 192.168.1.1
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Posted on Apr 13, 2009
I didnt find the 8 digit pin number anywhere on the router of DIGISOL DG-BR4015N, please help me if u know dat number...
Login into 192.168.2.1 it will ask you for username and password default username is admin and password is password here click on wizard-> wireless-> WPS there you will be able to find AP pin
Sep 28, 2012 | Computers & Internet
Cant remember the password
Push a pin into the reset hole at the back of the router for about 10 seconds.
Now the default username is (admin) and the default password is (admin).
If that wont work then leave the password field blank, and only enter (admin) as the username. Remember no brackets.
Jun 25, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I've forgotten my security password for the wireless and want to allow another computer access. as i'm not very technical is it difficult to reset andstart again?i don't want to be without the...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
Jul 18, 2011 | Zyxel (91-004-361002) Wireless Router
I forget my password and my user name
By default, the password is "admin" without quotes. Leave the username field blank.
If that does not work, you may have to resort to resetting it back to default settings. Do this by finding a paperclip or pin, and pressing the reset button in the back.
May 27, 2011 | Linksys Wireless-G WRT54G Router
What is routee password
Default password is "admin" (without the quotes, all lowercase) unless you have changed it with the configuration program on the CD. Leave the username field empty.
Apr 12, 2011 | Linksys Wireless-G WRT54G Router
What would username and password on login setup for Linksya wireless router?
factory default password and username
User: leave it in blank Password: admin
or
User: admin Password: admin
Mar 14, 2011 | Computers & Internet
How do i find my password for my router
normally, i wouild expect the password to be 'admin' without the quotes.
Oct 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
AirPlus Extreme Wireless G Router-Can't reset Username/Password
on this router, leave the username blank and enter admin in the password box.
Apr 18, 2009 | Linksys Wireless-G Broadband Router
142 people viewed this question
k24674
jasbo
jasbo
