Question about HP DVD1140i 22x Pata Multiformat Dvd Writer Burner
HP DVD writer 1140D doesn't recognize DVD's thinks drive is empty. Research on driver versions shows it's using Microsoft drivers. I would like to have the HP drivers to download that came with the DVD but the original software disc is missing.
  • HP Master
  • 4,924 Answers
All dvd writers have drivers on windows...and are installed automatically when windows is installed..If it started not to recognize dvd-es ...specially the ones burned in data format with multiple movies (avi ) ..even burned on it ...but sees the original ones..or sees the cd'es ..than the issue is with its lens ..and either you need a cleaning disk to clean it up ..or it is gone ...and need to be replaced..I personally have to do with something like this sand tried to update firmware ..installed original driver from the support site ,,and all the same ..Clean the lens and see how it is behaving ..and if it does the same ..just replace it ..cause they do have limited life time..otherwise you will end up with a lot of frustrations and no results...
Posted on Mar 18, 2011
    Brigadier General:
  • 10,406 Answers
It's not a problem of "device drivers", so don't bark up that (wrong) tree;
the software supplied by HP does _NOT_ include device-drivers.
Either:
1. the hardware has failed -- can it read any commercially-produced DVD disks?
If not, then replace the hardware.
2. there is software "inside" the device, called "firmware", that reads the volume-label
recorded onto the start of each "blank" disk. Either update the firmware, or
try a different brand of "blank" disks, because the current firmware is NOT accepting
as valid the volume-label on the current brand of disks. Newer firmware should recognize
the data on the volume-label.
I have an HP DVD+R/RW 16x10x32x4x2.4x8x Drive and i am trying to find the drivers for it to see if it works on my computer. I have tried typing up the Product Number and HP Part Number on the HP website,...
DVD-RW 16X HP DVD Writer 740b Drive Firmware Update ftp://ftp.hp.com/pub/softlib/software7/COL16063/pv-42566-1/sp26595.exe
you must be logged in as the computers administrator to install this update
or
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&cc=us&dlc=en&lc=en
Update your HP desktop computer to have the latest software and drivers available. HP provides many software and driver updates free of charge
hope this will help you
  • You must be logged on as an administrator to install this update.
  • HP DVD Writer 740b drive.
  • Blank floppy diskette, recordable CD (CD-R), or USB Thumb Drive.
  • Released: s.gif 2006-08-23 Version: s.gif HI24 Compatibility: s.gif Microsoft Windows XP
    Aug 21, 2011 | HP/5.25 16x10x32x4x2.4X8x IDE Carbon...
    The DVD writer doesn't recognize that there is a
    Most DVD drives are also CD drives, and it sounds like the DVD part is broken, you need to replace the DVD drive, this is done simply by buying a new one, I recommend Newegg.com ( if your unsure search exactly what you already have) then opening your case (tower) and just unplugging old one and plugging new one in, it really is very doable for even a novice.
    Jun 26, 2011 | HP Computers & Internet
    HP DVD Writer 1140d- Not reading DVD or CD's. for a while PC didn't recognize it. It also is a Lightscribe. i can burn labels. it just doesn't play DVD or CD.
    The read/play function of your device might be dead get a different player ( a used cheap one ) and just plug it in with the correct jumper settings and if it plays you have your answer, buy a new burner.
    Feb 04, 2011 | Computers & Internet
    I need the drivers for HP dvd1040e DVD Writer
    FOR ANY ONE WITH SIMILAR OR SAME PROBLEM
    GET all drivers and templates etc at:
    http://www.lightscribe.com/support/
    Check it out, worked to recognize my HP Super Driver. Download it all, include the diagnostic. Anybody who has a lightScribe should beable to use this.
    Dec 01, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    I lost my dvd, dvd writer drives system seems to
    Chances are either your drive has gone bad, or you have a bad Malware on your system. Go to http://www.malwarebytes.org and get the free version. Install it, and update it, then run it. If it finds stuff, do what the prompts tell you to do, and that should fix the problem. If not, then get another dvd drive. You shouldn't need special drivers beyond what MS Windows has to make your drive work.
    Feb 13, 2010 | Microsoft Windows XP Professional
    HP DVD 1040i
    I would email or call hp support and ask about this as there should be a firmware update of some description.
    Also re install latest chipset drivers and maybe adaptec aspi drivers ?
    Apr 17, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
    My system cannot recognize that I have a DVD drive.
    Have you tried to roll back the driver? If this doesnt work you may need to download the driver from somewhere online and reinstall the driver. Hope this helps. Please rate. Thanks
    Mar 05, 2009 | HP Media Center m7250n (ED842AA) PC...
    My LG dvd driver cant read certain dvds
    LG and HP in known for thier reading laser to become trashed or crash. Once this happens, you can only replace the drive.
    Sorry for the bad new but I faught an HP drive for months before I just bought a new one.
    Save yourself the hassle.
    Jan 22, 2009 | Computers & Internet
    HP DVD1140i 22x Pata Multiformat Dvd Writer Burner Logo
    403 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
