Question about Sharp EL509 Scientific Calculator
Can you tell me the type of battery a Sharp EL-509S calculator uses please?
informatica
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
SOURCE: Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Posted on Nov 27, 2007
SOURCE: ink problem
It has a little ink roller under the plastic on the right side as you are looking at it. It is made of black plastic and pulls straight up to come out
Posted on May 13, 2008
SOURCE: Sharp EL-1801V 12 Digit 2 Color Printer
SHARP EL-1801V DON'T KNOW HOW TO SET THE DATE AND TIME
Posted on Jun 12, 2008
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
Using a sharp el-738 calculator to find square roots
To get a square root sign on the SHARP calculator press 2nd F 3 (you will see in orange the square root above the 3) then type in the number you would like to find the square root and press equals
Mar 31, 2013 | Sharp EL-738 Scientific Calculator
Calculating square roots using a sharp el-738 calculator
On the calculator press 2nd F 3 to get the square root sign, then type in the number you would like to find the square root of and press equals.
Can't get rid of deg in sharp calculator
It simply indicates that the calculator is set to degrees. The calculator has three angular modes (degrees, radians, and grads). No matter which mode you set, the appropriate indicator will light up.
Dec 06, 2012 | Sharp Scientific Calculator El-509s,...
Sharp el-470 travel clock calculator
How do I set the date on the Sharp EL-470 travel clock calculator?
Oct 08, 2010 | Office Equipment & Supplies
Manual for calculator sharp el 573
My Sharp El-573 calculator is in scientific mode and nothing I do will put it back in regular arithmetic mode. Please tell me how to switch it back. Thanks for any help! Barbara
Dec 20, 2009 | Sharp Office Equipment & Supplies
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
Nov 01, 2007 | Sharp EL-2630P Calculator
Sharp EL509 Scientific Calculator Logo
126 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
